![]() | Home > Maintenance & Modifications > TDV8 MAP sensors clean |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Have you noticed a difference? |
Yes I got a 20% improvement but I added some Millers Diesel Power Eco Boost to the tank at the same time so I don't know which made the difference ![]() ![]() |
tommy-boy Member Since: 09 Jan 2011 Location: North East Posts: 96 ![]() ![]() ![]() |
I did this also just a couple of weeks back.
Tommy, that's good to hear. Were the MAP sensors fouled up and what mileage has the car done? Am very interested to hear if your mpg improves on your 600 mile trip. 2008 MY Java Black TDV8 HSE
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
i have cleaned mine and did notice there was an improvement in throttle response |
I'm 57plate TDV8 with just over 60k on the clock.
Just to update those interested.
Thanks for the feedback Tommy. Not bad for a high speed long run. I'm assuming your figures are the on-board computer. At slightly lower speeds my (unmapped) TDV8 shows about 29 on the computer and actual calculated is 26.5. This weekend got caught in the motorway hold up from hell on the M25 at junction 25: 3 hours going nowhere which has knocked the average down to 22.8 |
I've just pulled mine and they are mildly oily so re-fitted without cleaning.
Only takes a few minutes to spray them with carb cleaner so while they are out you may as well try it. Reset fuel consumption on the computer and see what happens? 2008 MY Java Black TDV8 HSE ![]() |
ok will do. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
I've just checked mine and they're just a little oily - more on one than the other interestingly. I think I'll pick up some carb cleaner next time I'm in town and give them a clean. Be interesting to see if it makes any difference. 2012 SDV6 - it's missing a couple of cylinders
TSLJon Member Since: 05 Mar 2012 Location: North Yorkshire Posts: 82 ![]() ![]() ![]() |
For you TDV8 chaps I had mine Terracleaned 2 weeks ago.
interesting
