![]() | Home > General > HEATED FRONT SEATS - to install? |
What model is the HSD? Here in the UK, we have the HSE which comes with heated seats as standard. I doubt there will be heated elements in the seats awaiting connection knowing how manufacturers will do anything to save costs. |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 331 ![]() ![]() ![]() |
I got in wrong.....it's an HSE. The machanic thinks Land Rover might have made 'one seat to fit all' as it were and if that is the case possible I could make use of the facility. Andrew Kennedy |
Whilst not knowing the answer, I'd be inclined to agree with Ady. Manufacturers are generally not in the hadit of leaving relatively expensive items in the cars unconnected, just because they are not specced..........but would be interesting to find out if it is the case. |
I thought the HSE had heated front seats as standard...or is that only in the UK? 2012 SDV6 - it's missing a couple of cylinders
It's worth a check, I remember on the Disco 2 everything was there, even the cables, all you needed were 2 switches. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263 ![]() ![]() ![]() |
I would be interested too as my Spain spec HSE Black doesn't have heated seats. 2013 RRS SDV6 Autobiography Fuji White
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Amazing really, do you have the buttons on the dash with the 3 amber segments? 2023 P440e SE Dynamic on order -cancelled
No but the spaces are there for them... Not normally a problem here but during ski season they are great to have!! My last 2 RRS were Uk spec. 2013 RRS SDV6 Autobiography Fuji White
Spain Spec, no FBH either. ![]() Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Hey SRE
