Home > General > HEATED FRONT SEATS - to install? |
What model is the HSD? Here in the UK, we have the HSE which comes with heated seats as standard. I doubt there will be heated elements in the seats awaiting connection knowing how manufacturers will do anything to save costs. |
Fri Dec 06 2013 11:38am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 324 |
I got in wrong.....it's an HSE. The machanic thinks Land Rover might have made 'one seat to fit all' as it were and if that is the case possible I could make use of the facility. Andrew Kennedy |
Fri Dec 06 2013 12:02pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Whilst not knowing the answer, I'd be inclined to agree with Ady. Manufacturers are generally not in the hadit of leaving relatively expensive items in the cars unconnected, just because they are not specced..........but would be interesting to find out if it is the case. ON THE WAY: BMW F21 M140i
Fri Dec 06 2013 12:59pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
I thought the HSE had heated front seats as standard...or is that only in the UK? 2012 SDV6 - it's missing a couple of cylinders
Fri Dec 06 2013 5:18pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
It's worth a check, I remember on the Disco 2 everything was there, even the cables, all you needed were 2 switches. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Fri Dec 06 2013 5:31pm |
paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263 |
I would be interested too as my Spain spec HSE Black doesn't have heated seats. 2013 RRS SDV6 Autobiography Fuji White
Sat Dec 07 2013 1:23pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1841 |
Amazing really, do you have the buttons on the dash with the 3 amber segments? 2023 P440e SE Dynamic on order -cancelled
Sat Dec 07 2013 1:46pm |
No but the spaces are there for them... Not normally a problem here but during ski season they are great to have!! My last 2 RRS were Uk spec. 2013 RRS SDV6 Autobiography Fuji White
Sat Dec 07 2013 2:55pm |
Spain Spec, no FBH either. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
Sat Dec 07 2013 3:52pm |
Hey SRE
Sat Dec 07 2013 5:06pm |
