![]() | Home > General > Another battery issue.. |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Think you might find that the fixing rods fit into holes that are higher in the cradle. As i said in a previous post Landrover fit Varta Batteries as Standard. 2.7 and 3.0 Are fitted with a 90amp 950amps(SAE)150 RC(mins) £69.80 From Jagland itisme |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
Thank you- I will try that |
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 ![]() ![]() ![]() |
thanks harrygh60 ![]() sent them a message to see how much it is with delivery ![]() hopefully with it being the same battery there will be no alternator issues |
Hey Harry Jagland did not have that battery and offered another which was not the same spec and only 80ah. Due to issues i decided to go with this battery - It seems to be the correct spec just the CCA is 720 and 90ah The company is pretty good and know their batteries + wanted to keep it the same 90ah which seems to be the important figure: http://www.ebay.co.uk/itm/271338129035#ht_1037wt_958 should arrive tomorrow. ![]() |
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 ![]() ![]() |
Just to add my new battery is working perfectly, cold starts the car in like a second. 100AH 900CCA for £85
Cheers Karan. |
It holds 10 more amp hours so that means a higher capacity compared to the original.
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 ![]() ![]() |
I also had my battery die on me aswell, looked around for alternatives and found the exide battery to be sufficient.
