Home > Technical > water ingress |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
sunroof or roof channel draining tubs become blocked?
Tue Nov 19 2013 1:47pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Find somewhere dry - open the sunroof - in each corner is a drain hole - pour water down the front ones & look for it exiting the car on to the floor by the wheel arch ( where the mud flaps would be ).
Tue Nov 19 2013 2:31pm |
If it is not blocked sunroof drains causing the problem it can be a worn seal around the roof panel. The seal is not 100% waterproof but is designed to keep the ingress of water within the ability of the sunroof drains to drain it away. If the seal is worn it lets in so much water in a downpour that the drains cannot cope and the channel in the sunroof recess overflows into the headlining and the water can find its way into all sorts of places - sometimes the interior lights and maybe the footwell down the A pillars. The fix is to replace the seal on the roofpanel but it is a bit fiddly. I had exactly this problem not on my RRS but on a Porsche 944 turbo.
Tue Nov 19 2013 3:21pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Thank you everybody for your advice. I think you have given me a flash of inspiration, I will go and look at the drain tubes from the sunroof. I reckon it must be that.
Thu Nov 21 2013 9:26am |
