Home > General > FBH.. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
No. If there is no timer system on your vehicle then the FBH only operates when you start the engine. It then looks at the temperature of the coolant, the ambient temperature and, I believe, the battery voltage. If the coolant and ambient temperatures are below certain threshold values and the battery has sufficient charge then it will start. 2012 SDV6 - it's missing a couple of cylinders
Fri Nov 15 2013 10:00am |
Slider Member Since: 04 Dec 2008 Location: In traffic Posts: 32 |
Thanks for the clarification...now need to find out if it can be upgraded to timed... |
Fri Nov 15 2013 10:57am |
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 |
I'd like to get my MY13 upgraded with timed and remote heating capabilities.
Fri Nov 15 2013 1:38pm |
JPR 1 Member Since: 29 Jan 2013 Location: Cheshire Posts: 435 |
Hello Slider, just had mine done on Wednesday by flack (mick) from this forum.
Fri Nov 15 2013 4:19pm |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
Slider, depends on the year of your RRS. Like this site? Buy some RRSPORT goodies to show your support! |
Fri Nov 15 2013 4:41pm |
I have a MY12 but it was built in November 2011 and if I understand correctly later build MY12's have the timed feature but the earlier build 12's do not.. |
Fri Nov 15 2013 6:20pm |
As I understand it, it's available from 2010 models onwards, same as the disco4's Bodsys Brake Bible
Fri Nov 15 2013 8:18pm |
Mines a 2012 (2013MY) SDV6 HSE Lux and doesn't have the timed capability. |
Fri Nov 15 2013 8:32pm |
I think the key word here is CAN have the capability
Mon Nov 18 2013 11:16am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Find the right Indy, And the price will plumet
Sun Nov 24 2013 9:15am |
