Home > General > FBH..
Slider
FBH..
Apologies for what may seem a dumb question...
I have the FBH but no timing capability so I believe that the system is a passive operation system...does that mean that when the car is sat in the airport car park when I am away on business every 'cold' morning the FBH chugs away of its own accord...warming things without need??? Confused
Post #402195 Fri Nov 15 2013 9:17am
No. If there is no timer system on your vehicle then the FBH only operates when you start the engine. It then looks at the temperature of the coolant, the ambient temperature and, I believe, the battery voltage. If the coolant and ambient temperatures are below certain threshold values and the battery has sufficient charge then it will start. 2012 SDV6 - it's missing a couple of cylinders
Post #402201 Fri Nov 15 2013 10:00am
Slider
Thanks for the clarification...now need to find out if it can be upgraded to timed...
Post #402215 Fri Nov 15 2013 10:57am
URX
Scotland
I'd like to get my MY13 upgraded with timed and remote heating capabilities.
anyone nearish to Edinburgh that can enable this for me? PM if you prefer Wink
Post #402242 Fri Nov 15 2013 1:38pm
JPR 1
Hello Slider, just had mine done on Wednesday by flack (mick) from this forum.
Now can set timer to come anytime and warm the car up.
I think it only operates though below a certain temperature Thumbs Up Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #402277 Fri Nov 15 2013 4:19pm
Martin
Site Administrator & Owner
Slider, depends on the year of your RRS. Like this site? Buy some RRSPORT goodies to show your support!
Post #402288 Fri Nov 15 2013 4:41pm
Slider
I have a MY12 but it was built in November 2011 and if I understand correctly later build MY12's have the timed feature but the earlier build 12's do not.. Sad
Post #402306 Fri Nov 15 2013 6:20pm
Bodsy
Site Sponsor
As I understand it, it's available from 2010 models onwards, same as the disco4's Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #402316 Fri Nov 15 2013 8:18pm
drdelrrs
Mines a 2012 (2013MY) SDV6 HSE Lux and doesn't have the timed capability.
Post #402317 Fri Nov 15 2013 8:32pm
URX
Scotland
I think the key word here is CAN have the capability
all after 2010 can have it but most dont as its a cost option at purchase time ...and not a cheap one for a software switch being enabled...
Post #402680 Mon Nov 18 2013 11:16am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
FBH
Find the right Indy, And the price will plumet
Harry itisme
Post #403431 Sun Nov 24 2013 9:15am
