Home > Maintenance & Modifications > [HELP] RRS Sport 2.7 Tuning Box Installation |
Dhups Member Since: 15 Sep 2013 Location: Essex Posts: 183 |
Hi Karan538
Thu Oct 31 2013 4:27pm |
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 |
http://www.ebay.co.uk/itm/DIESEL-TUNING-PE...5d26e3bc9b
Thu Oct 31 2013 5:46pm |
give the guy a call and ask...hopefully he will know. |
Thu Oct 31 2013 9:14pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
On an 08MY, it is on the passenger side (UK car ) of the engine, on the end of the fuel rail that runs just in front of the injectors.
Fri Nov 01 2013 6:53am |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 |
you can see you sensor on picture 1 and 3
Fri Nov 01 2013 6:54am |
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 |
Ive looked at these in the past for other vehicles & always decided against it, from what ive read they can cause problems and that you are always better off going for a proper remap.
Fri Nov 01 2013 8:14am |
Found the sensor thanks guys it is a 3 pin connector and is also clear in the instructions, going to install it now will keep you guys informed on performance/fuel consumption
Fri Nov 01 2013 1:22pm |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 |
Can't wait to see if this works! Its a good prize for about 228 horses on a sport tdv6 2.7 RRS 2006 2.7 HSE |
Fri Nov 01 2013 4:39pm |
Yes - interested to see too.
Fri Nov 01 2013 4:53pm |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Be very very careful that it is not the type which simply confuses the ECU by over fuelling to get extra bhp My wife had a well known tuning chip fitted to her Citroen C Crosser (same engine as the Freelander) and any heavy use of the throttle resulted in the car constantly going into limp mode, needing a short stop to allow the ECU to reset I would only ever go the remap route in future |
Fri Nov 01 2013 5:59pm |
Hi guys,
Fri Nov 01 2013 6:06pm |
How can you see if this is a safe box or not? RRS 2006 2.7 HSE |
Fri Nov 01 2013 6:34pm |
TBH I can't help you there. The one I mentioned was of a similar design from a well known company selling for more than double the one purchased by the OP. It also was only set on 3 of the possible 6 switches.
Fri Nov 01 2013 6:59pm |
Sounds good will give it a try. Just ordered mine should be here by next tueday... will let you know how i get on. |
Fri Nov 01 2013 7:42pm |
