Home > Maintenance & Modifications > [HELP] RRS Sport 2.7 Tuning Box Installation
Page 3 of 4 <1234>
Dhups
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Yep will do.
Post #401721 Mon Nov 11 2013 5:11pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Another tuning box at the same price: http://www.ebay.com/itm/Diesel-chip-tuning...27da712079
Any info about this company? RRS 2006 2.7 HSE
Post #401872 Tue Nov 12 2013 8:46pm
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
I don't have any info about that company but I can say after using it for nearly 2 weeks now my mpg is consistent at 24 to 26 from the 19 to 21 I was getting before.
Post #402011 Thu Nov 14 2013 1:41am
Dhups
got mine in today...was at the back of the engine...
this has made a difference...definitely less turbo lag and feels more responsive. Or may be that was just me deciding to put the foot down more Very Happy
For the price i would say it is worth it.
Like Karan would like to see if it makes a difference to my mpg over next few weeks.
Post #402431 Sat Nov 16 2013 5:59pm
RRSNorway
Tried to do a 0-60 with the chip? So we can see the improvment:) RRS 2006 2.7 HSE
Post #402556 Sun Nov 17 2013 7:01pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Karan, have you measured your fuel economy properly (brim to brim) or merely relied upon the vehicle computer?
As I mentioned earlier, these boxes gain the extra power through over fuelling the engine. It works, but at the end of the day it's your engine, and some are more sophisticated than others in what they measure and what safeguards are built in.
Many claim to be digital but contain no more than a simple resister. The less sophisticated ones can also cause more "diesel knock" when the engine is cold
Below is an extract from a publication summarising how they work. All of the limitations are overcome by a correctly calibrated remap since this will take into account adjustments to many other engine parameters monitored by the ECU. For clarity I'm not saying "don't buy tuning boxes" but having been there its a place I'd never go again!
Diesels aren't too fussy about Air/Fuel ratios, they will often continue to make power when incredibly rich, and producing huge clouds of black smoke. Take a look on Youtube at some of the big power Diesel Drag cars and trucks. In OEM Diesel tuning for the road, the limitations are usually based on the amount of smoke produced, and the amount of power the chassis can handle. Big BHP figures on a diesel are easy to make, and choosing the Tuner with the highest figure can sometimes be just picking the bravest. It's easy to be brave with someone else's engine. Intercepting the Rail Pressure sensor is the key to Tuning Boxes. The ECU/engine will control the pressure, and it uses its sensor to confirm this. This figure is vital for the ECU to known the fuel quantity.
Adding a resistor into this sensor circuit passes the wrong information to the ECU. What was 1500bar is now reported as 1400bar, so the ECU will activate the high pressure injection pump to raise the pressure by 100bar above the sensor value. The extra pressure will force more diesel through the open injector, and as mentioned, for a diesel, more fuel = more power. There is safety factors and tolerances built in, but in all cases, the Injector pump is now doing more work providing the extra pressure, and the Injectors are now holding back greater forces. The Torque and Smoke limiters have been bypassed as the ECU doesn't realise the greater fuel flow, and more interestingly, the MPG is screwed!
Economy and Tuning Boxes
From the original calculations in the ECU, and the Vehicle Road Speed, the ECU will be able to calculate the quantity of fuel used per unit of distance traveled. But what happens if the quantity of diesel injected is higher than the value the ECU is expecting? In this case, the economy will be overestimated as the ECU thinks it is using less diesel than reality. As with most external changes, if one calibrated component is disturbed, the knock on effects will be far reaching.
That's not to say that there isn't an increase in economy, there will be changes, and often the economy does increase, but certainly not to the level that the On Board Computer or Trip Computer thinks.
Post #402600 Sun Nov 17 2013 9:44pm
RRSNorway
Tuning box still going strong without any engine prob?
Could you do a 0-60 to see if its about the same as a ECU remap on 8.8 sec? RRS 2006 2.7 HSE
Post #412158 Sun Feb 02 2014 1:20pm
karan538
Everything is running well
Will give it a try when I can. Wink
Post #412161 Sun Feb 02 2014 1:53pm
RRSNorway
you do that;) Whistle RRS 2006 2.7 HSE
Post #412918 Thu Feb 06 2014 9:43pm
chelseablue06
2006 Range Rover Sport TDV6 HSE Buckingham Blue
Hi Guys I could really do with someone pointing me in the right direction as to where to find the correct plug. I have read through the thread and im sure its at the back of the engine being an 06 plate.
My photo seams slightly different to the first 2 and I just want to make certain im looking at the right plug before causing myself some issues Very Happy
My guess is that its located behind the silver rail running across the photo
Here is a close up of the plug I think is the right one
Post #414289 Sun Feb 16 2014 1:54pm
chelseablue06
Post #414290 Sun Feb 16 2014 1:55pm
Dhups
Hi
Mine was at the back of the engine in the middle too. It looks like the right one. I ended up getting my mechanic to install as it was awkward to get to.
Post #414293 Sun Feb 16 2014 2:38pm
chelseablue06
Thanks Dhups
I think I may be the same as I have spent far to long this afternoon attempting this and I need to get one with cleaning the car before it gets dark Very Happy
Jay
Post #414296 Sun Feb 16 2014 2:44pm
RRSNorway
you guys still going strong with this chip? any of you done a 0-60 yet to see the difference?
Post #425837 Sat May 31 2014 10:29pm
Grannyada
England 2006 Range Rover Sport TDV6 HSE Stornoway Grey
On the recomendation of a collegue i am thinking of buying a Speedhawk system.
Anyone got any experience of them and if so what sort of results did you get Got:
2006 RRS TDV6 HSE, 2017 AMG C43
BMW 1200GS
Not Got:
Sense, money
Post #426294 Wed Jun 04 2014 5:27pm
Page 3 of 4 <1234>
