Home > Maintenance & Modifications > [HELP] RRS Sport 2.7 Tuning Box Installation
Page 2 of 4 <1234>
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Will a chip box damage the engine in any way? is it safe to use?
What's the common problems?
Need to put the positive up against the negative before purchase. RRS 2006 2.7 HSE
Post #401102 Mon Nov 04 2013 9:48pm
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
Considering the seller I bought the box from has sold 50+ and has all positives for it I think that would be a good indication that the box causes no issues but also it does what it says on the tin.
It does NOT give you the ridiculous gains stated on the listing but does a fair bit which is worth the money spent
Very Happy
Post #401110 Mon Nov 04 2013 10:41pm
Dhups
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Hi Karan
Got mine today...will put it on tmr but did you adjust the level or just keep it standard?
Post #401124 Tue Nov 05 2013 12:30am
karan538
It comes on 3 as standard, I have mine set on 5 right now for performance
keep it on 3, have a drive, if you want more then put it on 4, but slowly increase for your preference. I reckon dont go higher than 6.
only change the level with engine fully off with keys out.
Have a good read through the instructions he sent you, explains everything about the dip switches & timing. Thumbs Up
Post #401126 Tue Nov 05 2013 12:58am
RRSNorway
Very Happy
Thanks for the input Thumbs Up
As long as you get more power and less turbo lag it's all good.
A remap here in Norway will be £499 but you will prob get the +38 bhp. RRS 2006 2.7 HSE
Post #401141 Tue Nov 05 2013 11:47am
Very Happy
Karen, are the positives received for the seller to do with the service the customers received from buying the item and not for how the chip has performed over a period of time knowing how the ebay feedback score works. I don't think you will get to hear about any failures on his feedback score. Whistle I certainly wouldn't trust a cheap chip in a very expensive engine.
Post #401145 Tue Nov 05 2013 12:30pm
i was going to say the same, the buyers will give him the thumbs up five stars because they posted it out ASAP
not a running history, unless they gave feedback X months afterwards
Post #401146 Tue Nov 05 2013 12:39pm
tanloverluke
Ady 555 wrote:
Karen, are the positives received for the seller to do with the service the customers received from buying the item and not for how the chip has performed over a period of time knowing how the ebay feedback score works. I don't think you will get to here about any failures on his feedback score. Whistle I certainly wouldn't trust a cheap chip in a very expensive engine.
i'd agree with you there Ady ! i'd rather have a 10% mpg improvement via the more expensive remap ! and if i was worried about the money, i would save 50 quid a month until i could afford one Thumbs Up Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #401147 Tue Nov 05 2013 1:12pm
Dhups
Thanks mate Thumbs Up
Haven't had chance to put it on beacuse at work most of the day and by the time I get back its dark. Will try and get it done at the weekend.
Very Happy
Post #401191 Tue Nov 05 2013 9:20pm
RRSNorway
Anymore good/bad about this box before I order one for my 2006 tdv6? RRS 2006 2.7 HSE
Post #401451 Fri Nov 08 2013 1:55pm
Dhups
Hi
I'm trying to install this to my car at the moment. But cannot locate the common rail sensor.
I don't think its in the same place a Karan mine is a early 2006 TDV6 2.7.
This this at the back of the engine in the middle?? (As in the the picture)
Any help appreciated.
Post #401627 Sun Nov 10 2013 12:47pm
karan538
Hi dhups,
Please take a full picture of the right hand side of the engine so I can spot the pressure sensor, cannot see it in your picture it is a bit lower.
Thanks
Post #401669 Mon Nov 11 2013 1:41am
adigorn
Dhups
Again its on you picture just behind the "tyre valve"
Silver "nut" with connector on it
Post #401672 Mon Nov 11 2013 7:49am
Dhups
Thanks Adigorn Thumbs Up
I thought that was it as I understnad it chaged for the later TVD6 engines so Karan's is in a different location.
Very Happy
Post #401679 Mon Nov 11 2013 11:47am
RRSNorway
Let us know how it feels on a tdv6 RRS 2006 2.7 HSE
Post #401712 Mon Nov 11 2013 5:11pm
Page 2 of 4 <1234>
