Home > Maintenance & Modifications > Roof Bars/Rails |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Thinking of adding roof rails but ruling out Genuine LR due to £410 cost
Thu Jun 27 2013 10:09am |
Cheers Chilly
Thu Jun 27 2013 10:51am |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 500 |
F150PICKUP wrote:
Thu Jun 27 2013 12:31pm |
That doesn't sound good Whippetman. I will probably only use the roof box once this year on the RRS and kayaks can now go on my sons car so didn't really want to fork out 3x cost for Genuine LR Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Jun 27 2013 1:14pm |
I have just fitted these today and not happy
Sun Sep 22 2013 7:36pm |
Sorry to hear that,but did try and warn you all!
Mon Sep 23 2013 6:05am |
I should have listened to you but thought for occasional use it was enough to spend - now regretting it
Mon Sep 23 2013 7:20am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
If you can get a saw on it, then you might be able to saw a slot in it and use a screwdriver. Need to be careful though as the metal can deform when you use the screwdriver. 2012 SDV6 - it's missing a couple of cylinders
Mon Sep 23 2013 1:44pm |
How much of the bolt is protruding? The traditional technique is to use an 'Erwin' stud extractor but there needs to be enough protruding to get the extractor onto it. 2008 MY Java Black TDV8 HSE |
Mon Sep 23 2013 1:59pm |
Whippetman - you may want to replace the locks with some Thule barrels - just noticed the ones supplied are thule copies but no key number so they must all have the same key
Tue Sep 24 2013 2:11pm |
My local land rover specialist has removed the offending bolt
Wed Sep 25 2013 6:00pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I bought a set of powerful bars and rails, cheap rubbish !! The cross bars although cheap are ok but the rails. Why don't L/R sell the rails separately, they do for D3's 2008 G4 RRSport TDV8 current
Fri Sep 27 2013 12:32pm |
Fri Sep 27 2013 12:43pm |
Kayak. The bars/rails do the job just poor quality 2008 G4 RRSport TDV8 current
Fri Sep 27 2013 12:48pm |
