![]() | Home > Maintenance & Modifications > Roof Bars/Rails |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Thinking of adding roof rails but ruling out Genuine LR due to £410 cost |
Cheers Chilly |
whippetman Member Since: 12 Jun 2010 Location: on the level Posts: 502 ![]() ![]() ![]() |
That doesn't sound good Whippetman. I will probably only use the roof box once this year on the RRS and kayaks can now go on my sons car so didn't really want to fork out 3x cost for Genuine LR |
I have just fitted these today and not happy |
Sorry to hear that,but did try and warn you all!
I should have listened to you but thought for occasional use it was enough to spend - now regretting it |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
If you can get a saw on it, then you might be able to saw a slot in it and use a screwdriver. Need to be careful though as the metal can deform when you use the screwdriver. 2012 SDV6 - it's missing a couple of cylinders
How much of the bolt is protruding? The traditional technique is to use an 'Erwin' stud extractor but there needs to be enough protruding to get the extractor onto it. 2008 MY Java Black TDV8 HSE ![]() |
Whippetman - you may want to replace the locks with some Thule barrels - just noticed the ones supplied are thule copies but no key number so they must all have the same key |
My local land rover specialist has removed the offending bolt |
I bought a set of powerful bars and rails, cheap rubbish !! The cross bars although cheap are ok but the rails. Why don't L/R sell the rails separately, they do for D3's 2008 G4 RRSport TDV8 current
Kayak. The bars/rails do the job just poor quality 2008 G4 RRSport TDV8 current
