Home > Technical > Smart Key Problem - Any ideas??
So, just went out tonight to sort my RRS out for a trip out tomorrow........and nothing, wouldn't open either when in range of the key or using the remotes Sad
Managed to finally get the boot to open and close, but the car will not recognise the smart key, even when placed under the steering column. Called LR assist and was told they couldn't get a technician to me until tomorrow morning Rolling Eyes . I was offered someone from the AA, but was told that they probably couldn't help and I should wait for a technician. Shocked
Anyone got any ideas in the meantime? ON THE WAY: BMW F21 M140i
Post #392789 Sat Aug 24 2013 9:31pm
Silly question but i will ask it anyway, have you tried the spare remote Bc Question
Try disconnecting the battery, then reconnect, see if it reset s itself. Expect a call from tracker if you do though. Wink
Ah, i see you quote remotes, so i assume you've tried the obvious.
Post #392790 Sat Aug 24 2013 9:48pm
Yes, thanks Ady, tried both sets, so something car related not keys Sad
Will wait for LR guy tomorrow. If I get bored in the morning I may try a battery disconnect. Thumbs Up ON THE WAY: BMW F21 M140i
Post #392794 Sat Aug 24 2013 10:28pm
muddywheels
Milk Float Man
I had this on a vogue loaner last year but it would start with key under steering column - it had to go back to dealer for a replacement module of some sort Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #392807 Sun Aug 25 2013 9:19am
MAW
Outside the house, usual and known parking space? Heard of some problems recently (on here I think) where powerlines and noise had blocked the smart key electronics...
Post #392809 Sun Aug 25 2013 9:33am
Thanks guys, well the LR tech came out and did a reset as Ady recommended and that seems to have solved it. Thumbs Up
Guy said they had had a lot of problems like this recently on Evoques, RRs's and FFRR's (he'd done 4 resets yesterday Shocked )
Said it may happen again, it may not Confused
So, were back on the road and hopefully a minor glitch, will keep you updated if it happens again.
Cheers Ady Thumbs Up ON THE WAY: BMW F21 M140i
Post #392812 Sun Aug 25 2013 10:58am
Triumph_Dave
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Hi Beancounter, as I have a MY13.5 HSE Black with the same locking system as yours, can you tell us how the Tech reset the system?, was it just a case of the battery disconnect or was it undertaken though the diagnostic port?
Dave
Post #392817 Sun Aug 25 2013 2:08pm
He disconnected both terminals, then ran a wire between both cables for around 20 seconds.
He then reset the one touch windows as apparently that gets thrown out when a reset/reboot gets done. ON THE WAY: BMW F21 M140i
Post #392839 Sun Aug 25 2013 9:50pm
Triumph_Dave
Great, thank you, standard battery reset.. I ran a Disco 4 before the RRS and its the same procedure, also same for windows..
Dave
Post #392840 Mon Aug 26 2013 12:15am
Your welcome Bc, pleased you are sorted and thank you for the useful advice, should it happen to others. Thumbs Up
Post #392864 Mon Aug 26 2013 8:16pm
