![]() | Home > Technical > Smart Key Problem - Any ideas?? |
Silly question but i will ask it anyway, have you tried the spare remote Bc |
Yes, thanks Ady, tried both sets, so something car related not keys |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
I had this on a vogue loaner last year but it would start with key under steering column - it had to go back to dealer for a replacement module of some sort |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Outside the house, usual and known parking space? Heard of some problems recently (on here I think) where powerlines and noise had blocked the smart key electronics... |
Thanks guys, well the LR tech came out and did a reset as Ady recommended and that seems to have solved it. |
Triumph_Dave Member Since: 11 Jul 2013 Location: Somerset Posts: 124 ![]() ![]() ![]() |
Hi Beancounter, as I have a MY13.5 HSE Black with the same locking system as yours, can you tell us how the Tech reset the system?, was it just a case of the battery disconnect or was it undertaken though the diagnostic port?
He disconnected both terminals, then ran a wire between both cables for around 20 seconds.
Great, thank you, standard battery reset.. I ran a Disco 4 before the RRS and its the same procedure, also same for windows.. Dave |
Your welcome Bc, pleased you are sorted and thank you for the useful advice, should it happen to others. |
