Home > Technical > HELP anyone please
tanloverluke
HELP anyone please
Hi guys well im back at the airport and following on from my post a week ago, the battery has died. Had to use the emergency key access and obviously cant start her. I bought with me a bqttery charger, ive disconnected the negative terminal, shes charging awsy now for 15 mins and the locking system works, lights, but not starting yet.
Am I totally Censored or will I have some luck with a little longer ?
Thanks[/u] Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #391392 Sat Aug 10 2013 6:27pm
tanloverluke
In case no one read my original poat, the reason I got myself in this Censored is because I left my dipped lights on. Apparently they should have turned off after a little while, and apparently the emergency battery cut off should have kicked in before she died completely, but none of this has happened Sad Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391393 Sat Aug 10 2013 6:30pm
roscopcoltrane
2008 Range Rover Sport TDV8 HSE Zermatt Silver
Give it some time, should jump OK, chargers take a while in my experience, airports usually have boosters?? good luck Very Happy
Post #391394 Sat Aug 10 2013 6:36pm
tanloverluke
Yep you would have thought they would have a booster, but just a regular charger.
With jump cables would the car start immediately ? Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391395 Sat Aug 10 2013 6:39pm
roscopcoltrane
As long as you dont jump it from a Corsa/Micra, it will still take time but only a couple of minutes, been there!! Last thing you need although you., at lest , were expecting it Sad
Post #391396 Sat Aug 10 2013 6:44pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Point on jump leads, quality does make a difference. Had a dead battery on the old TT, got some cheap leads and nothing, borrowed some beefy heavy duty ones and fired straight up Very Happy
Post #391402 Sat Aug 10 2013 8:29pm
roscopcoltrane
Good point + 1
Post #391404 Sat Aug 10 2013 8:46pm
tanloverluke
Thanks guys! The RAC fixed it in end as the charger was taking ages (1 hour and still nothing but a couple of clicks from the starter) and the newborn was fed up so just wanted to get going!
Next step is to see if battery has been affected. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391411 Sat Aug 10 2013 11:53pm
Paddi
Glad you got it started. When a battery is completely discharged it often won't take any charge from standard charger but a smart charger will work by using a pulsed delivery. Batteries can survive total discharge or it can knacker them. The only way to find out is give it a complete conditioning cycle with a smart charger (CTEK brand is a good choice) and see how it goes.
Good luck Thumbs Up 2008 MY Java Black TDV8 HSE
Post #391422 Sun Aug 11 2013 8:42am
tanloverluke
Thanks for that Paddie !I'll get the battery charged at the weekend and see how it goes. RAC gave it a boost, drove it all way home and it's been fine ever since but out of caution i'll give it a full charge. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391516 Mon Aug 12 2013 1:29pm
Sounds like you might be ok, but as you say, best to double check.
Also would seem the alternator is working to charge it back up, so thats another good thing to know too Thumbs Up ON THE WAY: BMW F21 M140i
Post #391517 Mon Aug 12 2013 1:46pm
TST717
Scotland
The RAC should be doing a Battery Capacity test , this gives a printout of they state of your battery and will tell you if the battery is ok but only needs a charge r if the battery is Kaput!!
I had the same recently with the alarm having gone off whilst we were away from the RRS for a few days..... New battery = £200.........
Hopefully just a few hours on the C Tek.....Make sure that you cycle it on the charger........
TST TDV8 HSE....Gone but not forgotten ....class act
Cayenne S diesel.....850n/m....385bhp....the danglies ...
Post #391523 Mon Aug 12 2013 3:58pm
tanloverluke
TST, Paddi also used the word "cycle", does that mean that I should recharge the battery fully (with say the CTEK) several times over a day/week?
Apologies if the question is a little amateurish ! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391547 Mon Aug 12 2013 7:13pm
TST717
Scotland
Just as Paddi mentioned the CTek cycles the battery charging sequence( if the battery is healthy) therefore the starting point is knowing that all the cells in the battery are good.sometimes there can be one weak cell in the whole battery.
Depending on which type of CTek you have the charging or conditioning cycle has to be selected.if you have the time , the battery would maybe benefit from a couple of ' cycles' that means after you connect initially it will show orange led then battery symbol part filled up, then over the charge Period it will go to 'full' and green led.If you have time do this twice.
The battery will be fully charged after this then run your RRS with no lights or as little electrics running as possible to allow the alternator to charge the at terry on a longish run at normal constant speeds.
Good luck,
Post #391553 Mon Aug 12 2013 7:59pm
tanloverluke
Thanks for that TST. I'll certainly take the time to do that ! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Post #391602 Tue Aug 13 2013 9:43am
