Home > Technical > Alignment |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9016 |
Not sure how having adjustable suspension helps here. The toe or camber aren't altered from the alignment settings by the system as the suspension is used. I guess they built all of the adjustments in to allow for slightly bent/pulled components over time... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Fri Aug 09 2013 3:31pm |
Interesting BC. Not sure why setting the vehicle to TTM for the alignment should cause rear tyre wear unless they're not doing all of the adjustments correctly. I understand that there is a certain order in which the components should be adjusted. Be interesting to hear their thoughts on why TTM causes rear wear.
Fri Aug 09 2013 3:35pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Will let you know, going to try and pop down there next weekend.......but know doubt there will be a list of jobs Mrs Bean has for me, so.................will probably be the one after ON THE WAY: BMW F21 M140i
Fri Aug 09 2013 3:40pm |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Well I've finally found somewhere who has the right kit and seems to know what they're doing, with a quote of £50 which sounds pretty good? Can't fit me in until Friday so I'll update after that |
Sat Aug 10 2013 12:47pm |
£50 sounds pretty good. I think LR charge about £160 but then they do charge £silly/hr anyway... 2012 SDV6 - it's missing a couple of cylinders
Sat Aug 10 2013 2:09pm |
The girl on the phone who sounded pretty knowledgable said it woul take about 45 mins, though I've heard others say about 90? Hopefully they'll do the job properly |
Sat Aug 10 2013 8:26pm |
60 mins seems about right depending on what needs to be done. 2012 SDV6 - it's missing a couple of cylinders
Sat Aug 10 2013 11:17pm |
