![]() | Home > Technical > Alignment |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Not sure how having adjustable suspension helps here. The toe or camber aren't altered from the alignment settings by the system as the suspension is used. I guess they built all of the adjustments in to allow for slightly bent/pulled components over time... 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Interesting BC. Not sure why setting the vehicle to TTM for the alignment should cause rear tyre wear unless they're not doing all of the adjustments correctly. I understand that there is a certain order in which the components should be adjusted. Be interesting to hear their thoughts on why TTM causes rear wear.
Will let you know, going to try and pop down there next weekend.......but know doubt there will be a list of jobs Mrs Bean has for me, so.................will probably be the one after |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Well I've finally found somewhere who has the right kit and seems to know what they're doing, with a quote of £50 which sounds pretty good? Can't fit me in until Friday so I'll update after that |
£50 sounds pretty good. I think LR charge about £160 but then they do charge £silly/hr anyway... 2012 SDV6 - it's missing a couple of cylinders
The girl on the phone who sounded pretty knowledgable said it woul take about 45 mins, though I've heard others say about 90? Hopefully they'll do the job properly |
60 mins seems about right depending on what needs to be done. 2012 SDV6 - it's missing a couple of cylinders
