Home > General > Cam belt change |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Not quite Southampton, but have the locking tools required. Not far from Longleat. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Jul 31 2013 9:19pm |
tizifred Member Since: 22 Jun 2013 Location: Southampton Posts: 17 |
Thanks for the offer simple1
Wed Jul 31 2013 9:32pm |
Have to be doing something fairly daft to break these
Wed Jul 31 2013 9:38pm |
the pins are pretty std, as Simple says, the only way realy of breaking these, is to try starting the engine with them in
Wed Jul 31 2013 9:46pm |
I may do it myself when I get 10 mins.
Wed Jul 31 2013 9:51pm |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 288 |
Always change the metalwork.
Wed Jul 31 2013 9:54pm |
id always change the tensioner (should get one with the timing belt kit) as well as idler bearings and also consider changing the water pump as is very simple with the belt off. Bodsys Brake Bible
Wed Jul 31 2013 10:16pm |
Wouldn't bother changing belts without tensioners and water pump. If the belts are due changed then the pump has done @ 100k miles so for five more bolts and some sealant just plain daft to forget it.
Wed Jul 31 2013 10:23pm |
Cheers guys |
Thu Aug 01 2013 7:59am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
A must is both the belts two tensioners and bolts, both idelers, auxullary belt and tensioner, optional is the water pump, I have done dozens of belts and only changed two water pumps at the customers request as both pumps where fine when replaced its your call to replace it.
Thu Aug 01 2013 3:07pm |
Steve
Thu Aug 01 2013 10:30pm |
It's all here....
Thu Aug 01 2013 10:41pm |
Thanks Steve
Thu Aug 01 2013 10:44pm |
Yes they are and I drew the short straw for this Saturday. 8-12 Paul Redding
Thu Aug 01 2013 10:45pm |
