Home > General > Cam belt change
tizifred
Cam belt change
Hi Guys
Does anyone know the cheapest place in the Southampton area that can do a cam belt change for my 06 2.7 RRS. I would do it myself but the tools are £100 to start with
Cheers guys
Post #390560 Wed Jul 31 2013 8:23pm
simple1
Not quite Southampton, but have the locking tools required. Not far from Longleat. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #390567 Wed Jul 31 2013 9:19pm
tizifred
Thanks for the offer simple1
I don't really like using other people's tools in case I damage/break them
Thanks anyway
Post #390570 Wed Jul 31 2013 9:32pm
simple1
Have to be doing something fairly daft to break these Rolling with laughter
Two cam pins and flywheel lock. Two hours to do front belts on D3, and the same to do pain in backside rear pump belt Big Cry 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #390571 Wed Jul 31 2013 9:38pm
Bodsy
Site Sponsor
the pins are pretty std, as Simple says, the only way realy of breaking these, is to try starting the engine with them in Laughing
sets are £65 on ebay if you want your own.
LR wil charge anywhere between 600-900, indipendants will be charging abouit £500, so you can save yourself a packet if you are able to change them yourself. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #390572 Wed Jul 31 2013 9:46pm
tizifred
I may do it myself when I get 10 mins.
Is it best to change the tensioner as well, or are these normally ok
Post #390573 Wed Jul 31 2013 9:51pm
Advanced Factors
Site Sponsor
Always change the metalwork.
i can fix you up with OE Dayco parts and lend you the tools. Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #390574 Wed Jul 31 2013 9:54pm
Bodsy
Site Sponsor
id always change the tensioner (should get one with the timing belt kit) as well as idler bearings and also consider changing the water pump as is very simple with the belt off. Thumbs Up Bodsys Brake Bible
See it HERE
Post #390577 Wed Jul 31 2013 10:16pm
simple1
Wouldn't bother changing belts without tensioners and water pump. If the belts are due changed then the pump has done @ 100k miles so for five more bolts and some sealant just plain daft to forget it.
Listen to the Meastro.... Bow down he knows his onions Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #390578 Wed Jul 31 2013 10:23pm
tizifred
Cheers guys
Post #390589 Thu Aug 01 2013 7:59am
flack
A must is both the belts two tensioners and bolts, both idelers, auxullary belt and tensioner, optional is the water pump, I have done dozens of belts and only changed two water pumps at the customers request as both pumps where fine when replaced its your call to replace it.
From 2007 on its a must to change the oil pump as well as quite a few of this year have had failed front belt tensioners due to the oil pump casing failing and trashing the engine.
Flack Thumbs Up
Post #390630 Thu Aug 01 2013 3:07pm
tizifred
Steve
How much for the front and rear kit?
Post #390661 Thu Aug 01 2013 10:30pm
Advanced Factors
Site Sponsor
It's all here....
http://www.advancedfactors.co.uk/engine-pa...t-26-c.asp Paul Redding
+44 (0)23 8052 2776
Post #390662 Thu Aug 01 2013 10:41pm
tizifred
Thanks Steve
I may pop in Saturday to get them if in stock
Post #390663 Thu Aug 01 2013 10:44pm
Advanced Factors
Site Sponsor
Yes they are and I drew the short straw for this Saturday. 8-12 Paul Redding
+44 (0)23 8052 2776
Post #390664 Thu Aug 01 2013 10:45pm
