Home > Maintenance & Modifications > Side Step + service advice needed
sunseeker
United Kingdom 2013 Range Rover Sport TDV6 Autobiography Santorini Black
Hi there
I bought my 06 RRS from the Land Rover dealer a few years ago with the side step already damaged
http://rrsport.co.uk/gallery/displayimage....&pos=0
http://rrsport.co.uk/gallery/displayimage....&pos=1
[I have saved the images on the gallery...I cant seem to attach the images in the message]
The passenger side step is totally functional, just deeply grazed (how the previous owner did that, I have no idea)
I am thinking about getting this unsightly fixed
Any suggestions
1. Change a single step for a new one (then where can I source a single passenger side, step)
2. Change the pair (although drivers side is completely fine), should it only be OEM or do you suggest an alternative
3. Is it possible to just fix the edge
4. Other ideas I havent thought off
Service
Finally my car was serviced at 62k (I cant remember exactly) just less than a year ago and the mileage stands at 68k. My sticker from the LR service centre highlights I should have a major service at 1 year/77k @£1700 Big Cry which involves some sort of timing belt change.
Is that right? and should this service be so expensive?
[/img] Oh wow
Post #390383 Mon Jul 29 2013 8:25pm
Paddi
You can buy new trim for the sidesteps. Have a look at this recent thread: http://rrsport.co.uk/forum/topic31814.html 2008 MY Java Black TDV8 HSE
Post #390392 Mon Jul 29 2013 9:42pm
sunseeker
Thanks for your help...will order Oh wow
Post #390396 Mon Jul 29 2013 10:01pm
P7tey
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
The TDV6 is engine requires the timing and fuel pump belts etc changed at 105k miles / 7 years, so yes yours is due. £1700 sounds expensive even for a dealer. You can normally get the belts and tensioners done for around £400 or so by an independent. I recall some on this forum negotiating around £1000 for LR to do the full 7 year service, belts and everything else. Hope this helps, if you want to read more then have a search, there are a lot of threads relating to people's experiences on here Thumbs Up
Post #390401 Tue Jul 30 2013 4:58am
Saeedasghar
2006 Range Rover Sport TDV6 HSE Java Black
Its worth ringing around I recently had my 7 year service ( both belts and tensioners) transfer box oil change and rear diff oil change from LR stourbridge for £980inc all parts labour and vat.
Post #390419 Tue Jul 30 2013 8:44am
