Home > General > Wobble at 50-55MPH
g8lmh
Wobble at 50-55MPH
Good morning all.
Anybody else have a wobble at 50-55MPH? Very strange as it is only between this speed.
Below and above the steering wobble is not an issue.
Surely if this was balancing it would occur at all speeds?
Cheers for any assistance.
Lee.
Post #389478 Sun Jul 21 2013 10:41am
simple1
No if its bent rims it will be at all speeds, balancing is usually speed related. Sounds like the glue got hot and your weights fell off. Had exactly same issue on Thursdsy with mine Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #389482 Sun Jul 21 2013 12:53pm
BKHK
It could be many things, balance, mud in the wheels, buckled wheel, damaged wheel, brakes, steering rack, or rear diff.
No, vibes are not always apparent at all speeds so its not easy to track down the cause other than by elimination. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #389483 Sun Jul 21 2013 12:54pm
Paddi
Re: Wobble at 50-55MPH
Nope. It's a harmonic so occurs at specific speeds. Will be worse at double that speed. Steering wobble at a certain speed is usually indicative of wheel imbalance but start by checking you don't just have anything like mud adhering to the inner rims. Check your tyres for uneven wear too which might suggest you have either worn suspension components and/or need a four wheel alignment check 2008 MY Java Black TDV8 HSE
Post #389484 Sun Jul 21 2013 12:55pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Same as mine
Had
wheeles balanced
Moved wheels front to back
4 wheel tracking done ( hunter system ) no change and the tacking was well out
Now replacing front lower arms as there is play in the rear part of the arm
Also spotted the center bearing on the prop has worn/split 40% of the outer rubber so prop is moving more around more than it's ment to Big Cry will it ever end Big Cry
Post #389498 Sun Jul 21 2013 4:30pm
mdcbigdave
Site Sponsor
I'd wager its your ball joints starting to give out
Had it on the D3 (like yours but with a bigger shell) and 'twas the pesky ball joints.
Thumbs Up All things transport and logistics, international and national shipping.
Its a small planet after all.
info@md-couriers.co.uk
Post #389500 Sun Jul 21 2013 5:15pm
ShooterNeil
Upper or the lower one on the arm under the driveshaft/ hub
Post #389501 Sun Jul 21 2013 5:25pm
jack.bauer
can you describe the wobble a little more?
i too have had a similar experience that was bloody frightening ... as thought the car was wobbling side to side like its about to give in. also around 50-60mph
i do have worn bush and the lower arm is due replacement
also believe wheels were not aligned
are these likely the cause then?
should be going in this week for the above repairs 07 TDV8 + BAS map
Post #389509 Sun Jul 21 2013 7:31pm
