Home > General > Wobble at 50-55MPH |
g8lmh Member Since: 04 Jul 2013 Location: Lancaster Posts: 67 |
Good morning all.
Sun Jul 21 2013 10:41am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
It could be many things, balance, mud in the wheels, buckled wheel, damaged wheel, brakes, steering rack, or rear diff.
Sun Jul 21 2013 12:54pm |
Nope. It's a harmonic so occurs at specific speeds. Will be worse at double that speed. Steering wobble at a certain speed is usually indicative of wheel imbalance but start by checking you don't just have anything like mud adhering to the inner rims. Check your tyres for uneven wear too which might suggest you have either worn suspension components and/or need a four wheel alignment check 2008 MY Java Black TDV8 HSE |
Sun Jul 21 2013 12:55pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Same as mine
Sun Jul 21 2013 4:30pm |
mdcbigdave Site Sponsor Member Since: 23 Apr 2013 Location: cornwall Posts: 104 |
I'd wager its your ball joints starting to give out
Sun Jul 21 2013 5:15pm |
Upper or the lower one on the arm under the driveshaft/ hub |
Sun Jul 21 2013 5:25pm |
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 |
can you describe the wobble a little more?
Sun Jul 21 2013 7:31pm |
