Home > Technical > RRS Suspension Fault - Light on dash - help please!
RRS09
United Kingdom 2009 Range Rover Sport TDV6 HST Santorini Black
Hi, I've had a yellow warning light coming on on the dash of my RRS (09) with the arrows on each side concerning the suspension. Symptoms are as follows:
• Lift the car to normal mode from access mode, drive up the road, the light comes on and disables the centre control module and the directional arrows and brings up the message 'suspension fault - normal ride height only'.
• the car remains in Normal Mode, suspension doesn't move unless i switch off the engine and then restart it, the light on the centre console then re illuminates as normal.
• I've had the car diagnosed by a garage and the fault code comes back as 'U0416-94'. MY2009 Range Rover Sport Stormer 2.7 TDV6
Post #386803 Mon Jun 24 2013 2:16am
http://www.rrsport.co.uk/gallery/albums/us...zation.pdf
Bottom of page 3 Thumbs Up RRS gone
Post #386809 Mon Jun 24 2013 9:24am
Bobby
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #386814 Mon Jun 24 2013 10:30am
GIXER JOHN
2006 Range Rover Sport TDV6 HSE Santorini Black
Probably the compressor mate. Just had same problem on my2006 .
Fitted new amk compressor. Sorted Thumbs Up Very Happy
Post #386823 Mon Jun 24 2013 11:23am
RRS09
[quote="GIXER JOHN"]Probably the compressor mate. Just had same problem on my2006 .
Fitted new amk compressor. Sorted Thumbs Up Very Happy[/quote]
Thanks for your feedback Gixer John, did your car flag up the same fault code as this? I have been told that the compressors are quite common for going however i want to make sure its definitely that before changing it. MY2009 Range Rover Sport Stormer 2.7 TDV6
Post #386843 Mon Jun 24 2013 5:15pm
Chrale
If your car is fitted with Dynamic Response, check the fluid level. I had same fault, turned out to be leak on one of the ARB's. 2007 TDV6 HSE
Post #387407 Sun Jun 30 2013 5:47am
RRS09
Thanks for your feedback Chrale, whether it makes any difference i've had 4 new anti-roll bar bushes and link rods alround last year, or do you mean the roll bar itself? Where do i check the fluid level? Thanks again. MY2009 Range Rover Sport Stormer 2.7 TDV6
Post #387415 Sun Jun 30 2013 11:31am
Chrale
The ARB's themselves can leak. Theres a reservoir on drivers side just behind front panel under bonnet. Looks like a power steering reservoir.
See photo attached.
http://www.rrsport.co.uk/gallery/albums/us...ervoir.jpg 2007 TDV6 HSE
Post #387448 Sun Jun 30 2013 10:40pm
