![]() | Home > Technical > RRS Suspension Fault - Light on dash - help please! |
http://www.rrsport.co.uk/gallery/albums/us...zation.pdf
GIXER JOHN Member Since: 05 Sep 2012 Location: pinxton nottingham Posts: 13 ![]() ![]() |
Probably the compressor mate. Just had same problem on my2006 .
RRS09 Member Since: 02 Sep 2012 Location: Wales Posts: 10 ![]() ![]() ![]() |
[quote="GIXER JOHN"]Probably the compressor mate. Just had same problem on my2006 .
Chrale Member Since: 14 Feb 2013 Location: North East Posts: 77 ![]() ![]() ![]() |
If your car is fitted with Dynamic Response, check the fluid level. I had same fault, turned out to be leak on one of the ARB's. 2007 TDV6 HSE |
Thanks for your feedback Chrale, whether it makes any difference i've had 4 new anti-roll bar bushes and link rods alround last year, or do you mean the roll bar itself? Where do i check the fluid level? Thanks again. MY2009 Range Rover Sport Stormer 2.7 TDV6 |
The ARB's themselves can leak. Theres a reservoir on drivers side just behind front panel under bonnet. Looks like a power steering reservoir.
