Home > Technical > Name this part and its purpose - please ? |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
I beleive they are the harmonic dampeners, there to reduce noise though they shouldnt be banging things |
Sun Jun 09 2013 2:49pm |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
no, think those are on the axle, or similar, maybe on/near crankshaft ? RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Sun Jun 09 2013 2:54pm |
OK found this
Sun Jun 09 2013 3:05pm |
can someone check their 'dangly' bits and tell me if they too hit the bumper or exhaust tips ? maybe the mounts on mine are worn and are dangling/swaying too much ? Lol RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Sun Jun 09 2013 3:42pm |
msramsden Member Since: 24 Apr 2013 Location: Lancashire Posts: 11 |
I was just about to ask the very same question, I noticed them earlier when giving the under carriage (the cars not mine) a clean.
Sun Jun 09 2013 4:13pm |
Yeah, I've found a fair bit of info about them, and the reasoning behind it, but don't see why they should move so much and hit surrounding objects. I bet many bushes etc have been replaced due to these ! Lol RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Sun Jun 09 2013 4:22pm |
I suppose a solution could be to stick some dense sponge/foam on them at the points they make contact with the surrounding areas. Might reduce the noise they make when they clatter the surrounding metal. TDV6 HSE - Rimini Red
Sun Jun 09 2013 4:41pm |
well, to test that these were the cause of the knocking, I stuffed a few old rags around them, and the noise all but went, but the one is too close to the exhaust tip to keep something stuffed in there for too long - unless I wanted flames coming out of my exhaust ! RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Sun Jun 09 2013 5:02pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
Are the exhaust tips the original fit items or aftermarket replacements? 2012 SDV6 - it's missing a couple of cylinders
Sun Jun 09 2013 5:30pm |
They are there because it was a cheap fix for LR as they couldn't be bothered to design out the harmonics so the easiest way was to hang some heavy weights in various locations to 'tune' out the unwanted sympathetic vibrations. They obviously contribute to why the RRS weighs so much as you're carrying around several kilos of deadweight.
Sun Jun 09 2013 5:32pm |
original I'll see if new rubber mounts can be bought for them, but a quick look tells me that half the car has to come apart just to get at them ! Is there flame proof rubber out there to pack around them ? Lol RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition Prefer RR Vouge S/C but they don't do Orange ! |
Sun Jun 09 2013 5:54pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Just had a peep underneath and sure enough mine swing like the 60s!!
Sun Jun 09 2013 5:59pm |
and think how many have changed bushes etc only to still have the noise ?
Sun Jun 09 2013 6:04pm |
Yep mine swing happily - the nearside seems to bang the underside of the car and the offside catches the rear bumper and the underside of the car. FF 4.4 V8 Soooo looking forward to this bad boy
Sun Jun 09 2013 6:16pm |
