Home > General > Not so bullet proof TDV8
Page 13 of 22 <123 ... 121314 ... 202122>
What a pain in the arxe......literally Embarassed
Hope they sort it out for you quickly Thumbs Up ON THE WAY: BMW F21 M140i
Post #383568 Mon May 20 2013 11:59am
simple1
Ady it's not the sort of thing that floats my boat Rolling with laughter
As it only does it under load and not in neutral there is a bit of head scratching going on. If it is a shield or cover then usually do it all the time I would think. Let the professionals work it out Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #383574 Mon May 20 2013 1:03pm
Bodsy
Site Sponsor
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter And STILL you're smilling Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #383575 Mon May 20 2013 1:07pm
simple1
Ian
Made of strong stuff me.... My normal would be ram raid the show room window but the front bumper is already damaged so not really any other option Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #383576 Mon May 20 2013 1:13pm
mse
simple1 wrote:
Ian
Reverse in? Mike
2014 Facelift Discovery
Post #383578 Mon May 20 2013 1:28pm
simple1
With or without the tow bar fitted Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #383579 Mon May 20 2013 1:30pm
mse
With, saves removing it Whistle Rolling with laughter Mike
Post #383582 Mon May 20 2013 2:00pm
simple1
Well to save the glazing, a nice man is coming with a Disco later and car is first in the que to be sorted tomorrow. Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #383606 Mon May 20 2013 5:20pm
pjb
Just thought I should post to get you off page 13 you've had enough bad luck Exclamation Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #383700 Tue May 21 2013 5:23pm
pjb
nearly on page 14
I think you must be a saint to have been so understanding & tolerant Paul
L405 Loire Blue
Swift Conqueror 645
Abarth 500c
Post #383701 Tue May 21 2013 5:24pm
muddywheels
Milk Float Man
How about now Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #383702 Tue May 21 2013 5:35pm
muddywheels
Milk Float Man
Cant even get that right Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #383703 Tue May 21 2013 5:35pm
simple1
Friday the 13th, 13th page...... It's all bad luck. Spoke to Guy Salmon this afternoon and they are still non the wiser.
Have had a sense of humor failure with Land Rover Exec office by email as I don't think I would have been able to control my temper talking to someone. Tamping would be closer. Took four weeks to get the engine changed once they had it, then had to take it all to bits again to change turbo after whistle. If they say body is going to have to come off again I am going to throw towel in and demand a cheque. Finally had enough Censored Censored ! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #383715 Tue May 21 2013 8:08pm
muddywheels
Milk Float Man
I think you have been incredibly patient Shocked
Enough is enough - they need to offer you an unbelievable deal on a new one or your money back so you can buy a vehicle that works Evil or Very Mad
Your experience is enough to put anyone off buying a LR vehicle Big Cry Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #383722 Tue May 21 2013 9:27pm
drdelrrs
I don't see how blindly taking the body off will help. There is no way to see a vibration; it must be diagnosed before stripping surely.
There are the obvious stuff like bent pulleys on alternator, A/C compressor etc. which should be visible and audible if you use a stethoscope on the engine block.
In my opinion, other possibilities to ask the dealer is they're view on whether, if the vibration is engine speed related and occurs at the same band of revs in every gear I'd suspect a faulty injector or injection timing.
The other possibility is you have a sticky inlet valve causing a slight miss-fire.
Post #383829 Wed May 22 2013 6:36pm
