Home > General > 2008 TDV8 HSE Ipod connection
woodcutter
Been lurking for a while and waiting for the right car to come along, and next week ill be swopping my Navara for my dream car! wondered if anyone knows if there is anyway i can connect the ipod to the car.
Post #382049 Thu May 02 2013 9:29pm
simple1
As a 2008 it should have Bluetooth as standard so that takes care of the phone. iPod/iPhone can be connected by two male 3.5 mm jack lead which plugs into rear of centre console. Press aux on radio and off you go, iPod plays but no control from head unit. Bit agricultural and there are plenty on here that has gvif units fitted by Bodsy which also works well. Thumbs Up
Welcome to the forum, I'm sure you will enjoy your new toy Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382053 Thu May 02 2013 9:57pm
woodcutter
Thanks for the reply
Post #382060 Fri May 03 2013 7:10am
Paddi
The jack to jack lead will work but if you use one of these the sound quality is better. Smile
http://www.amazon.co.uk/gp/aw/d/B007QTAHTC
Plus the USB facilitates charging if you combine with a cigar lighter adapter but
Make sure you use one of the newer type with a choice of higher current output or your device will not charge. Enjoy your new toy! 2008 MY Java Black TDV8 HSE
Post #382074 Fri May 03 2013 9:24am
simple1
Gonna give one of them a go. Fed up with two wires from the back. Would love a more permanent solution but having had custom bracket and cradle which made radio surround sit squiff and made noises, I binned it. Shame there is no way of plugging it into dock in arm rest, unless someone can tell me different. iPhone 5 in case you can Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382123 Fri May 03 2013 4:12pm
tommy-boy
England 2008 Range Rover Sport TDV8 HSE Stornoway Grey
You can get the factory fitted iPod connector they are in eBay occasionally. I fitted mine in the top box, this then charges the pod and gives track selection through the steering wheel. Sound quality is better than any jack socket. Also get a USB port with it so I can download more onto a USB stick if I so wanted. 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!!
Post #382141 Sat May 04 2013 7:46am
cmcb
Scotland 2008 Range Rover Sport TDV8 HST Stornoway Grey
I have a 2008 HST- was the Bluetooth ability to play music available on my car? Thanks. I currently use the male to male jack and it works really well albeit is old fashioned RRS TDV8 HST
BMW 330Cd M Sport
Post #382167 Sat May 04 2013 3:29pm
simple1
No you can't stream music by Bluetooth. One thing I have done is read the radio manual from start to finish Whistle I was trying to get the voice command part to work but it doesn't understand the Somerset accent too well Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #382179 Sat May 04 2013 5:24pm
Streaky
United Arab Emirates 2008 Range Rover Sport Supercharged Alaska White
Take a look in my gallery for pictures of the Kuda system....the phone holder is Case Logic and they also do a version for the Iphone 5.
I have the aftermarket LR Interface to control the stereo from the steering wheel also...worth the money if you ask me. No more wires sprawling across the armrests into the rear sockets.... Thumbs Up Ra-Ro Sport Super Dooper Charged.
Ford F350 Super Duty Prototype.
Ni$$@n Patrol 4.8 Overlander.
Post #382286 Mon May 06 2013 3:18pm
simple1
Got one of these, but word to the wise, if you use a copy iphone5 adaptor it doesn't work. £29.95 Apple version does however Big Cry 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #383429 Sat May 18 2013 11:35am
