Home > General > 2008 TDV8 HSE Ipod connection |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
As a 2008 it should have Bluetooth as standard so that takes care of the phone. iPod/iPhone can be connected by two male 3.5 mm jack lead which plugs into rear of centre console. Press aux on radio and off you go, iPod plays but no control from head unit. Bit agricultural and there are plenty on here that has gvif units fitted by Bodsy which also works well.
Thu May 02 2013 9:57pm |
woodcutter Member Since: 04 Apr 2010 Location: Lake District Posts: 23 |
Thanks for the reply |
Fri May 03 2013 7:10am |
The jack to jack lead will work but if you use one of these the sound quality is better.
Fri May 03 2013 9:24am |
Gonna give one of them a go. Fed up with two wires from the back. Would love a more permanent solution but having had custom bracket and cradle which made radio surround sit squiff and made noises, I binned it. Shame there is no way of plugging it into dock in arm rest, unless someone can tell me different. iPhone 5 in case you can 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri May 03 2013 4:12pm |
tommy-boy Member Since: 09 Jan 2011 Location: North East Posts: 96 |
You can get the factory fitted iPod connector they are in eBay occasionally. I fitted mine in the top box, this then charges the pod and gives track selection through the steering wheel. Sound quality is better than any jack socket. Also get a USB port with it so I can download more onto a USB stick if I so wanted. 08MY HSE 3.6 TDV8 Stornoway Grey, Twisted performance cat back... and shed loads of extras!!! |
Sat May 04 2013 7:46am |
cmcb Member Since: 16 Jan 2013 Location: Edinburgh Posts: 33 |
I have a 2008 HST- was the Bluetooth ability to play music available on my car? Thanks. I currently use the male to male jack and it works really well albeit is old fashioned RRS TDV8 HST
Sat May 04 2013 3:29pm |
No you can't stream music by Bluetooth. One thing I have done is read the radio manual from start to finish I was trying to get the voice command part to work but it doesn't understand the Somerset accent too well 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat May 04 2013 5:24pm |
Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259 |
Take a look in my gallery for pictures of the Kuda system....the phone holder is Case Logic and they also do a version for the Iphone 5.
Mon May 06 2013 3:18pm |
Got one of these, but word to the wise, if you use a copy iphone5 adaptor it doesn't work. £29.95 Apple version does however 2x TDV6. SE and HSE. Both returned to sender with issues👀 TDV8 Sport HSE...... Gone. Loved it but it didn't love me!! Now rolling in MY10 Fullfat TDV8 Vogue. Slammed it to go round corners🙈 Cruising daily #56 mph in a Volvo V8. 😱 Lots of other toys in the cupboard...😜 |
Sat May 18 2013 11:35am |
