Home > General > Dashboard Plastic Speaker Cover Creak |
rabcnesbit Member Since: 29 Jun 2010 Location: London Posts: 95 |
Ahh, so that's the creaking sound I hear sometimes then! |
Sat Apr 27 2013 10:18am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Yep usually the grill or side or seat rubbing centre console. The grill is held in by four plastic lugs that push into metal clips. Do it when dash is warm as I did it on cold day and broke two lugs off. Fitted new one with sticky felt between dash and grill. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Apr 27 2013 12:01pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
If you use a PLASTIC type paint scraper as a wedge, it should be possible to un clip without breaking any lugs. Its not an easy area being so close to the screen. Once you have taken it off, do as simples says, use some felt between grille and dash. I sometimes use black foam drought excluder from the hardware store. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sun Apr 28 2013 3:30am |
Sun Apr 28 2013 6:04am |
Nice diagram Bobby 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sun Apr 28 2013 12:37pm |
