Home > Maintenance & Modifications > Spare tire winch not working :( |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
Get a helper, and pull down on the cable while you unscrew it. If that does not work, you may be able to take yours apart and unjam the cable.
Fri Apr 19 2013 9:07pm |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 |
How can I take it apart? 91 BMW 850CSI |
Fri Apr 19 2013 9:13pm |
Brianx5 Member Since: 30 Jan 2013 Location: AYRSHIRE Posts: 36 |
I had the similar problem, once you remove the winch drill out the 4 rivets and take it appart rewind the wire and rebuild and pop rivet back together again remember to grease it up, if not repairable e-bay approx £90. |
Sat Apr 20 2013 2:41pm |
How did you put it back together after drilling it out? 91 BMW 850CSI |
Sat Apr 20 2013 4:57pm |
Rebuilding is the reverse of...
Sat Apr 20 2013 5:36pm |
As mse has said once you find the fault rewind back on the spool and use large flange pop rivets to secure the top hat remember to insert the rivets with flat upwards |
Sat Apr 20 2013 10:06pm |
