Home > Technical > Battery Drainage Unfixable at Land Rover
Page 3 of 3 <123
baxc
carnt believe they never replaced the switch out of all the things they replaced this would be the first and the cheapest tell them to replace the switch first Thumbs Up
Post #379425 Tue Apr 02 2013 2:53pm
Tim in Scotland
One more shot in the dark.......... in the very early days of RRS there were problems like this that were traced back to the earthing strap for the gearbox - it had come loose and fallen off. Freelander2 also suffered this problem at one stage. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #379429 Tue Apr 02 2013 3:46pm
drdelrrs
My money is on faulty electornic in the alternator.
Post #379437 Tue Apr 02 2013 6:18pm
TIAB
United Kingdom 2007 Range Rover Sport Supercharged HST Java Black
I have the same problem, mine exists when I have opened and closed the doors a few times, getting kids seats in and out and alike. - I will be checking the tailgate switch.
Dealership states that the battery is fine.
Clarksons recent Top Gear review of the RR also infers known problems with batteries going flat: http://www.topgear.com/uk/jeremy-clarkson/...2013-03-18 "Also, I am assured that the battery no longer goes flat every time you want to go somewhere"
Post #379452 Tue Apr 02 2013 7:26pm
Meccles
Australia 2013 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
I wonder about the brake light switch? SWMBO reported that the brake lights were on dimly when she hopped out of the car after it failed to start. I know that this switch has caused other issues and is a fine quality Ford part Rolling with laughter My car has just been returned again with a shrug of the shoulders and "we cant find anything wrong". Whistle SWMBO owns this car I get to drive occasionally Smile
Post #379475 Wed Apr 03 2013 7:52am
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
This all getting rather frustrating.
Have they seen your vehicle with any faults or are they going from your veerabl communication.
Land Rover have actually seen my vehicle play up and issues with the Nav Screen and the drainage but are still unable to fix it.
They have advised the upper tailgate switch has been reaplaced and they have been leaving the car over night and starting it the following day and it appears to be fine.
Sods Law when it gets to me I will have the issues again I feel.
Lets see what happens.
Meccles, if your car is under waranty why dont you get them to replace your car?
Post #379485 Wed Apr 03 2013 10:01am
Meccles
Ahh because the law in OZ doesn't require them to. Went as far as barristers LR are doing all they are legally required. We have no real recourse Sad The law is very weak in this regard in OZ All they have to do is "fix it" as per what they believe is fixed. To go further requires court cases etc which are very expensive and not guaranteed results. SWMBO owns this car I get to drive occasionally Smile
Post #379782 Sun Apr 07 2013 8:09am
K80tcg
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Did you get this sorted, I have the exactly the same problem.
I am waiting for a tail gate switch.
The sat nav appears to run on the same side of the loom.
Have you tried pulling the fuse to see if there is still a power drain Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #383087 Tue May 14 2013 7:58pm
Paddi
He did - but posted it on another thread - see this link http://www.rrsport.co.uk/forum/topic30527.html
The upper tailgate switch is easy to fit but strongly recommend taking off the upper tailgate trim panel so you can access the switch with less chance of damaging the thing when you install it . Be prepared to find all sorts of filth and rust under the trim panel. (apologies if you already knew all that). 2008 MY Java Black TDV8 HSE
Post #383148 Wed May 15 2013 12:50pm
Harry HST
Tailgate switched repalced at land rover however same problem persists.
The issue causing the drain is the satnav/radio freezing and doesnt turn off at times.
Land Rover still dont know what's causing this at all, if they haven't a clue who has!
Post #383977 Fri May 24 2013 12:13pm
K80tcg
Harry have you changed the battery.
I had the same problem, battery tested fine and held charge but kept going flat next mroning after i changed the tailgate switch.
Local garage said you have a fault cell, borrow a battery and see what happens been fine since.
Landrover were going to chnage the ECU! Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #383980 Fri May 24 2013 12:22pm
Harry HST
Battery replaced still same problem now going through litigations with LR!!
Have spoken to several land rover specialists but know one has a clue
Post #384221 Tue May 28 2013 9:07pm
Harry HST
The main issue now is that the Nav screen and radio freeze and do not turn off at times.
Post #384223 Tue May 28 2013 9:09pm
Rangiesport06
Australia 2006 Range Rover Sport 3.0 TDV6 HSE Java Black
Battery drainage problems
I have a RRS 06 that has a battery drainage problem! I have worked out the navigation unit is coming on when the car is locked. Can someone help me with this problem Big Cry Is there a way I can deactivate the navigation? Please help!!! Sick of getting up in morning not knowing if the car will start
Post #446630 Mon Dec 29 2014 7:28am
Page 3 of 3 <123
