Home > General > 6m wait + purchase = oh ye...h?
Battery looks a little low but the charging figure looks about right. Might be a sign of a tired battery... 2012 SDV6 - it's missing a couple of cylinders
Post #378054 Sun Mar 24 2013 4:48pm
jack.bauer
hmmm funny you say that, i have also discovered the parking sensors do not work and reading up on old threads, i noticed mention of potential battery problems....
basically when i engage the reverse, rather than hear the "confirmation" tone that the sensors are engaged, i hear a long high pitched sound, followed by the parking button flashing amber on the dash. the sound is coming from the back rather than the front. i did the test which was recommended in couple of old threads whereby you switch the ignition to I/II, engage reverse and put your ear against each sensor. I cannot hear any sort of clicking sound whatsoever from any of the sensors!
ref:
1. the useful post by bobby in here http://www.rrsport.co.uk/forum/topic23033.html?highlight=satnav
2. robmeister's post in here http://www.rrsport.co.uk/forum/topic29177....g+flashing
i have pm'd the robmeister general.
Post #378104 Sun Mar 24 2013 8:55pm
Tim in Scotland
Also check that your rear lights are all working, failed lamps in the light units can throw up strange warnings. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #378158 Mon Mar 25 2013 9:15am
simple1
If you get a continuos tone from rear once in reverse you have a faulty sensor or failed rear bumper loom. Not uncommon. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378161 Mon Mar 25 2013 9:24am
jack.bauer
do the front sensors work in this scenario or is it all broken?
Post #378258 Mon Mar 25 2013 8:19pm
simple1
Fronts should work independently as the sound for these comes from speaker under dash that gives indicator sound Laughing strange I know. Front looms also prone to rubbing through Big Cry 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378261 Mon Mar 25 2013 8:26pm
jack.bauer
yep theyre fine
Post #378286 Mon Mar 25 2013 10:17pm
jack.bauer
Fault reading results from local landy specialist.
1 suspension control valve needs replacing as well as one of the rear sensors. They're going to draft the costs. How much worth of repair is that?
Active roll control module
C1B07-19
Directional control valve 2
Current circuit above threshold
Parking aid control module
B1B44-01 rear right outer sensor
General electric failure 07 TDV8 + BAS map
Post #378685 Wed Mar 27 2013 10:42am
GSJordan
2006 Range Rover Sport Supercharged Bonatti Grey
C1B07-19
Hi Jack,
Did you resolve your issues with these repairs? How much did they cost? I've picked up a car second hand today with both of those faults (PDC and Suspension Lean) but seems to be related to battery power - i.e. if I take the car for a long run before restarting the engine it seems fine...
I'd appreciate any help/advice before I get it looked at.
Gary
Post #390730 Fri Aug 02 2013 11:15pm
BKHK
Change the battery for a new one, its always a good idea. It could also be alternator, depending on age of the car. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #390735 Sat Aug 03 2013 7:13am
Agreed. Use a LR battery too. The new ones they use are a tad pricey but at least you can then rule out the battery. 2012 SDV6 - it's missing a couple of cylinders
Post #390736 Sat Aug 03 2013 7:31am
jack.bauer
C1B07-19
Hi Jack,
Gary
hi Gary
sorry to hear of your troubles. my issues were not battery related. the PDC was a faulty sensor and the suspension issue required a valve replacement. These came at under £400 07 TDV8 + BAS map
Post #391020 Tue Aug 06 2013 12:23am
