Home > General > Brake Discs & Pads
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
Brake Discs & Pads
The light has just come one to replace the pads so I will do the discs at the same time
Any preference or suggestions on which to go for .?
Post #377873 Fri Mar 22 2013 8:07pm
simple1
Depends on lots of things. Is it first set of pads to be reaced, is there a big ridge or rust on the disc? If they are Brembos, get oe discs and pads. If its rears then decent quality copy parts are plenty good enough. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377879 Fri Mar 22 2013 8:51pm
Kimmea
The pads would have been done in the past by the previous owner.
Yes its Brembos thats on it..Just so mny options out there and the prices vary quite dramatically .!
No there is no ridge on the disc faces but there is the usual age relates rust marks on then.
Post #377994 Sat Mar 23 2013 7:59pm
simple1
My advice would be to fit genuine pads to Brembos. I tried spurious pads and the car really didn't stop that well, so went to dealers and bought genuine. If the discs are fine don't change them. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #377999 Sat Mar 23 2013 8:45pm
RobP
I agree. For Brembos use genuine pads and discs TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #378011 Sun Mar 24 2013 12:44am
I understand that the pads used by LR are actually made by Ferrodo irrespective of the brake system used. 2012 SDV6 - it's missing a couple of cylinders
Post #378014 Sun Mar 24 2013 8:35am
shepp
The front pads are labelled up as made by brembo, it says brembo on the back of the pads.
The rrp is around £120, but dealers over buy to get a larger discount on parts. So you can find front pads, from a dealer, on ebay for around£90
http://www.ebay.co.uk/itm/320937254736
Post #378015 Sun Mar 24 2013 9:36am
shepp
Post #378021 Sun Mar 24 2013 9:58am
shepp
Post #378024 Sun Mar 24 2013 10:07am
simple1
Just in case you didn't get it the first time Shocked Rolling with laughter
Pads I have are in a LR parts box but say Brembo stamped into the metal backing. Am sure the brake material is outsourced but I doubt we will ever know its actual manufacturer. I think my pads were £143 inc vat when I picked them up at service in case I needed some between then and next service. Didn't realise it was going to be parked up long term. Crying or Very sad Rolling Eyes 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378026 Sun Mar 24 2013 10:31am
Disco_Mikey
You can buy uprated EBC brake pads for half that price.
Redstuff are recommended for everyday use, and Yellowstuff for "spirited" driving Whistle
Post #378031 Sun Mar 24 2013 12:49pm
simple1
Have you tried them Mikey? Interested to know how they perform when cold. Only ever used green stuff which are great when warm but don't stop you at all when cold. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378032 Sun Mar 24 2013 12:59pm
Disco_Mikey
I used Redstuff, and thought they were amazing. Almost no brake dust from them, and initial bite was great, and only got better as they got warmer. Just make sure they are the ceramic compound Thumbs Up
Have not used Yellowstuff yet, but have heard good things about them too...
Post #378034 Sun Mar 24 2013 1:42pm
simple1
If and when the beast returns, I might give that a go, my wheels go black within a day of being washed so anything that reduces this is good Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378045 Sun Mar 24 2013 2:40pm
Disco_Mikey
I certainly had no issues with brake dust. Were even cleaner than using OEM pads Thumbs Up
Post #378047 Sun Mar 24 2013 3:49pm
