Home > General > Brake Discs & Pads
scott7
Scotland
I've used green stuff pads front and back and found them to be excellent, just about to fit a full set again.
Post #378069 Sun Mar 24 2013 5:53pm
Whizzee111s
England 2010 Range Rover Sport Supercharged Santorini Black
I've used and have fitted green stuff pads on my lotus and they are excellent just need to make sure they are ok for the S/C Freelander SE - Gone
S1 Elise - weekender
Rrsport S/C Autobiography 10 plate -well and truely here, but now stolen
Post #378076 Sun Mar 24 2013 6:43pm
simple1
Always used green stuff on RS4 on rears and carbon mix AP pads on front. It stops a 1650 kg estate rather well. Found that until they have a little bit of heat in them they squeal a bit. The OE land rover pads are actually quite good but can't work out why they create so much dust and eat discs. By rights it should be one or the other. Unless the dust is the discs Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378094 Sun Mar 24 2013 8:06pm
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
Thanks guys, think ill go order a set of EBC green Stuff to see how I get one.
Post #378123 Sun Mar 24 2013 10:43pm
Disco_Mikey
[quote="simple1"]Found that until they have a little bit of heat in them they squeal a bit. [/quote
Forgot about that part Embarassed
Mine squealed for around 500-600 miles, until they were bedded in properly. Once bedded in, there was not a sound from them Thumbs Up
Post #378142 Mon Mar 25 2013 6:43am
simple1
If your looking, item number eBay Item No. 280594141479 on fleabay. Thumbs Up 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378154 Mon Mar 25 2013 8:53am
Kimmea
Cheers but its a tdv6 with brembos..!
So I just go for the Yellw Stuuf instead Thumbs Up
Also the part numbers differ from site to site for the same pads.!
They seem to say ( brembo) for the tdv8 but not tdv6
Post #378162 Mon Mar 25 2013 9:25am
simple1
You will need to find out if these were retro fit or not. If they are then possibly off a supercharged in which case I think it's the same pad/disc as TDV8 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378166 Mon Mar 25 2013 9:34am
Kimmea
These were factory fit at a guess as the previous owner wouldn't have swapped them out at a guess
Post #378167 Mon Mar 25 2013 9:37am
simple1
Don't know what year your car is but when I ordered my second V6 @ 2006, these were not an option and were fitted to SC only. In 2007 they were standard fit on V8 so think a call to supplying dealer may help. Have seen a few v6 and discos with Brembos but when you talk to owners, they have fitted them themselves. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378171 Mon Mar 25 2013 9:45am
Kimmea
Hmmmm ok I'm out of the UK but home tomorrow so ill check that out then.
It's an 2007 57.
Post #378175 Mon Mar 25 2013 9:53am
simple1
Sent you a PM 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #378179 Mon Mar 25 2013 10:03am
