![]() | Home > General > Brake Discs & Pads |
Depends on lots of things. Is it first set of pads to be reaced, is there a big ridge or rust on the disc? If they are Brembos, get oe discs and pads. If its rears then decent quality copy parts are plenty good enough. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Kimmea Member Since: 10 Jul 2012 Location: Aberdeenshire Posts: 259 ![]() ![]() ![]() |
The pads would have been done in the past by the previous owner.
My advice would be to fit genuine pads to Brembos. I tried spurious pads and the car really didn't stop that well, so went to dealers and bought genuine. If the discs are fine don't change them. 2x TDV6. SE and HSE. Both returned to sender with issues👀
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
I agree. For Brembos use genuine pads and discs TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
I understand that the pads used by LR are actually made by Ferrodo irrespective of the brake system used. 2012 SDV6 - it's missing a couple of cylinders
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
The front pads are labelled up as made by brembo, it says brembo on the back of the pads.
Just in case you didn't get it the first time |
You can buy uprated EBC brake pads for half that price.
Have you tried them Mikey? Interested to know how they perform when cold. Only ever used green stuff which are great when warm but don't stop you at all when cold. |
I used Redstuff, and thought they were amazing. Almost no brake dust from them, and initial bite was great, and only got better as they got warmer. Just make sure they are the ceramic compound |
If and when the beast returns, I might give that a go, my wheels go black within a day of being washed so anything that reduces this is good |
I certainly had no issues with brake dust. Were even cleaner than using OEM pads |
