![]() | Home > Technical > RRS 2006 TDV6 Engine seized? |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
Sounds very much like timing belt snapped or belt tensioner detached, same destructive effect,(becoming a quite common occurrence with pre '09 TDV6's), really hope it's not this,as it will more than likely require a replacement engine . RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
livonian Member Since: 09 Mar 2013 Location: Oxford Posts: 4 ![]() ![]() |
Thanks. Hope you're wrong but that's what the RAC man thought too! |
06MY's were usually OK for cambelt tensioners falling off. It was the 07/08MY's that had issues...
Any news on the outcome of this livonian |
Ok, the LR dealer has now had a look and they say they 'can't turn the engine manually, it's looking like the crank has seized'. They've drained the oil, there's 'metal in the sump' so there 'seems to be an internal failure of the engine'. They're quoting 'worst case scenario' £10,500 inc vat for new engine and new turbo, for which I get a one-year guarantee.
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
You must be gutted |
78,600 miles and FSH. Will give it a try, thanks, but won't hold my breath! |
Be very wary of "re-manufactured" or "re-conditioned" engines. JLR + PSA do not supply replacement parts for the bottom end of the TDV6 engine. You cannot buy pistons, rings, main bearings or big end bearings. There is also no aftermarket suppliers of said parts either. After exchanging a few emails with various "specialists" they are not even willing to supply the parts to anyone to re-build their own engine ![]() ![]() I am in exactly the same situation as yourself, and have done a lot of research over the last few months ![]() |
Don't take no for an answer - 78k is nothing |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
Would Ford (US) sell parts? Here in Oz the same engine is in the Ford Explorer. Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
I thought the Explorer was only the petrol V6 - do you mean the Territory. I would have thought the ACCC would jump on a car company that only supplied complete engines and not component parts. Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
H16UUP Member Since: 23 Aug 2010 Location: Stockport Posts: 31 ![]() ![]() ![]() |
Hopefully using Fuchs Pro-S 5w30 oil every time mine has an oil change will give my '06 a long and healthy life |
Oops - yes, I meant the Ford Territory Diesel! Cheers, Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers 2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT |
Leytonstone Member Since: 21 Feb 2013 Location: Leytonstone Posts: 11 ![]() ![]() ![]() |
Hi, actually there are aftermarket main bearings and big ends that we have managed to get which were specifically manufactured to address the problems associated with the failed mains and bigends. ill post a picture [/img] |
