![]() | Home > General > Range Rover Gone Bang |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33 ![]() ![]() ![]() |
Hi Guys
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 ![]() ![]() ![]() |
Sorry to hear that |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Gutted for you |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 ![]() |
ugh, did you only buy it 6 months ago too?
AntRover Member Since: 28 Feb 2013 Location: Warwickshire Posts: 50 ![]() ![]() |
Scotty, sorry to hear that... it sounds like the cam belt gave up and left you with a pile of scrap twisted metal for an engine?
A recent spate of blown engines on here should be a big concern for us all |
The vehicle is 7 years old (according to the OP's avatar) so it is due a change. And apparently it was booked in to be done in April. So in fairness to LR, the thing has gone right about the time it was due to be changed. I tend to go early on cambelts because the potential fallout from them is so great but that's maybe just me. I notice that some manufacturers now recommend age or mileage for cambelts. I think VAG now say X miles or 5 years. That shouold catch a few people out. It might be worth the OP having a word with LR about some help with the costs if the vehicle has been serviced correctly and the belt change isn't late. If it's late then all bets are off, of course. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Leytonstone Member Since: 21 Feb 2013 Location: Leytonstone Posts: 11 ![]() ![]() ![]() |
These engines are notorious for having the main engine and conrods bearings failing. Somehow, somewhere in Range Rover they have got this critical part of the engine wrong with countless amounts of engine failures now! |
Hi guys,
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 ![]() ![]() |
The oil pump casing has a lug with a threaded hole in it, that is the mounting for the timing belt tensioner. This lug is not man enough for the job on pre '09 TDV6's. (LR have changed part no's several times on these oil pump casings, so they know damn well about the weaknesses of these components). The cast alloy lug fractures and of course the belt tensioner falls away,losing belt tension, then parts of the engine go bang due to untimed contact. |
Personally i would expect L/R to be picking up the bill for a nw engine then if they are fully aware of these failures |
Hi guys
