Home > General > Range Rover Gone Bang |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
cheers for clearing that up |
Fri Mar 08 2013 12:26pm |
5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33 |
Hi Guys
Mon Mar 11 2013 9:20am |
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 |
Sorry to hear that
Mon Mar 11 2013 9:42am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2793 |
Gutted for you 16MY Estoril Blue SVR.............
Mon Mar 11 2013 10:34am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Mon Mar 11 2013 11:43am |
sagalout Member Since: 26 Feb 2013 Location: Harrogate Posts: 128 |
ugh, did you only buy it 6 months ago too?
Mon Mar 11 2013 12:44pm |
AntRover Member Since: 28 Feb 2013 Location: Warwickshire Posts: 50 |
Scotty, sorry to hear that... it sounds like the cam belt gave up and left you with a pile of scrap twisted metal for an engine?
Mon Mar 11 2013 2:56pm |
A recent spate of blown engines on here should be a big concern for us all
Mon Mar 11 2013 3:30pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
The vehicle is 7 years old (according to the OP's avatar) so it is due a change. And apparently it was booked in to be done in April. So in fairness to LR, the thing has gone right about the time it was due to be changed. I tend to go early on cambelts because the potential fallout from them is so great but that's maybe just me. I notice that some manufacturers now recommend age or mileage for cambelts. I think VAG now say X miles or 5 years. That shouold catch a few people out. It might be worth the OP having a word with LR about some help with the costs if the vehicle has been serviced correctly and the belt change isn't late. If it's late then all bets are off, of course. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Mar 11 2013 4:16pm |
Leytonstone Member Since: 21 Feb 2013 Location: Leytonstone Posts: 11 |
These engines are notorious for having the main engine and conrods bearings failing. Somehow, somewhere in Range Rover they have got this critical part of the engine wrong with countless amounts of engine failures now! |
Mon Mar 11 2013 9:22pm |
Hi guys,
Mon Mar 11 2013 9:26pm |
Texstar Member Since: 27 Aug 2006 Location: W.London Posts: 208 |
The oil pump casing has a lug with a threaded hole in it, that is the mounting for the timing belt tensioner. This lug is not man enough for the job on pre '09 TDV6's. (LR have changed part no's several times on these oil pump casings, so they know damn well about the weaknesses of these components). The cast alloy lug fractures and of course the belt tensioner falls away,losing belt tension, then parts of the engine go bang due to untimed contact. The worrying thing is, that you can have the timing belt etc changed, thinking you are wise and erring on the side of caution, then 1000 miles or whatever later, this lug fractures with the same catastrophic result as the belt snapping. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i |
Mon Mar 11 2013 9:41pm |
Personally i would expect L/R to be picking up the bill for a nw engine then if they are fully aware of these failures maybe a recall should of been released. |
Mon Mar 11 2013 9:56pm |
Hi guys
Mon Mar 11 2013 9:58pm |
