Home > Maintenance & Modifications > Turbo replacement on tdv8 |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
Sell it. Now.
Fri Mar 08 2013 10:34pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Not really. Body can be off in 2 hours... Also gives you the chance to replace the front and front-rear brake pipes at the same time. And if it does need any rear suspension bushes, it gives great access to replace them without stuggling with tight access or seized bolts |
Sat Mar 09 2013 8:09am |
Markos Member Since: 09 Dec 2007 Location: Ljubljana Posts: 187 |
Mikey really only 2h is it the same for Sport? At my local LR dealer they told me that they need approx.15h( body off and on again) 2008 RRS TDV8 HSE, Java black, Alpaca,..... |
Sat Mar 09 2013 2:46pm |
Body off in 2, providing there are no seized bolts to deal with. Each turbo is a couple of hours (ish), and allow 4 hours to refit body, bleed brakes, double check the work done and a road test |
Sat Mar 09 2013 3:49pm |
RRGirl Member Since: 06 Mar 2017 Location: Pretoria Posts: 2 |
hi Toplink, can you advise if the turbo can be replaced without body off, please provide guide or pics |
Mon Mar 06 2017 8:36am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
Hi RRgirl, as Mike said, it's better to do it body off and it will allow access to check a whole bunch of other things. --
Mon Mar 06 2017 9:42am |
Hi Naks, thanks but dont have the lifting equipment and ramp hence I am trying another way to access the turbos, any guidance and pics to assist |
Mon Mar 06 2017 9:51am |
