Home > Technical > RangeRover Sport MPG |
MisterAdam Member Since: 03 May 2012 Location: Liverpool, UK Posts: 352 |
The computers seem pretty inaccurate, i've seen mine in the low 20's, but also in the low 30's. Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Thu Feb 21 2013 11:40am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Depends on your driving style, but for a TDV6, I'd say that's a little on the low side from what I've seen posted on here previously, but again, depends what sort of roads you drive too, town/city or mortorways, A roads etc. ON THE WAY: BMW F21 M140i
Thu Feb 21 2013 11:41am |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1849 |
Hi Beancounter,
Thu Feb 21 2013 12:12pm |
Sure Jim, anything between 26, if I drive like a t t and as much as 34 on a longer run (driving <80mph, no fast acceleration etc).
Thu Feb 21 2013 12:24pm |
Thanks |
Thu Feb 21 2013 12:27pm |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
21.6 MPG seems rather low for the 2.7 RRS but as BC said it all depends on your driving style and roads. Most of my driving is around town. My last reset was over 3,500 miles ago and last time I checked MPG on the computer it was 27.5. The actual will certainly be much lower than that but I have not yet bothered calculating based on fill ups. I only check the consumption to monitor any relative drop which could indicate a problem, which I think is what you are doing as well. |
Thu Feb 21 2013 12:30pm |
AteeqM Member Since: 07 May 2012 Location: Ilford Posts: 4 |
Thank you all very much for the immediate response! I really appreciate it!
Thu Feb 21 2013 12:47pm |
^^^ Seems quite low then AteeqM . Could be worth flagging up to your dealer as unless you have lead feet you should be getting at least mid 20's. ON THE WAY: BMW F21 M140i
Thu Feb 21 2013 12:57pm |
Ha! I can assure you I am a sensible driver Thanks Bean and yes I will definitely be doing so, I thought something was strange as I heard this was supposed to achieve a higher MPG and am filling it up more often.
Thu Feb 21 2013 1:08pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9005 |
Are you running non-standard wheels/tyres? If you change the rolling circumference then that will alter the how far the vehicle thinks it's travelled. That shouldn't make much of a difference though, albeit it is a real effect. 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 21 2013 3:28pm |
57TDV8 Member Since: 16 Jan 2013 Location: Cirencester Posts: 113 |
I gat around 25mpg from my 57 TDV8 mix motorway/short trips.... 2010 TDV8... |
Thu Feb 21 2013 6:31pm |
SturgeRRS Member Since: 05 Jan 2013 Location: Surrey Posts: 96 |
Well for some reason mine is going down hill after a couple of weeks. On paper it's should be better on fuel then the Lexus it has replaced. For the first couple of weeks it was using around 30 squid a week as the missis only flits around here and there. Now it seems to be using 50 squid. I have questioned her severally and she said she isn't taking trips to the cost so am perplexed where this fuel is going. I was messing with the climate at the weekend, now tell me this, if you have it on auto does the AC pump run? The reason I ask is the AC light is on. MY 11 RRS Luxury Stornoway Grey Ivory/Black leather contrast stitching Logic7 side steps roof DVD system for the grand daughter. Mercedes SL500 for the summer. Vito Sport X for work. Gone to many to list but what larks |
Thu Feb 21 2013 6:51pm |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
checkout my topic at the beginning of winter for some results :
Thu Feb 21 2013 7:13pm |
I had a run out to whitby at the weekend, about 180 mile round trip i zeroed the trip computer which in turn zero's the mpg, although some of it was motorway and the rest is up hill and down dale as it is going to whitby (fantastic roads) i put mine in sports box aswel as dynamic mode also making full use of the paddleshift and just drove it like i'd stole it when i got back home i checked the computer and it was showing 30.7 mpg boy was it fun, you really can chuck the sport around on twisty roads |
Thu Feb 21 2013 8:28pm |
