![]() | Home > Technical > SMOKE FROM STEEL BREATHER PIPE UNDER FRONT BUMPER |
whiskey mac Member Since: 14 Oct 2012 Location: DONCASTER SOUTH YORKSHIRE Posts: 12 ![]() ![]() ![]() |
HI ANYONE HELP NOTICE WHEN I START ENGINE IN MORNING AND PULL OUT OF GARAGE THEN
FBH
thanks for info only had since oct still learning whats norma land wots not with rrs |
We usually see an influx of smoke out of bonnet/smoke from fron wing threads around Nov time |
Welderman Member Since: 14 Jan 2013 Location: Chorley, Lancashire Posts: 146 ![]() ![]() |
I did a search after mine did it last week lol, this sites great for looking up stuff for the RRS |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 ![]() ![]() ![]() |
FBH comes on automaticaly at temperatures below 5 degrees when the engine is cold to assist warming up. If you have the remote control / timer the FBH can be activated manually (park heat) MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
