Home > Technical > SMOKE FROM STEEL BREATHER PIPE UNDER FRONT BUMPER
whiskey mac
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
HI ANYONE HELP NOTICE WHEN I START ENGINE IN MORNING AND PULL OUT OF GARAGE THEN
SWITCH OFF SMOKE SEEMS TO COME OUT OFF A STEEL BREATHER PIPE UNDER FRONT BUMPER
ITS OK WHEN ENGINE RUNNING AND ENGINE SEEMS FINE ALSO SEEMS TO DO THIS WHEN ENGINE SWITCHED OFF . paul
Post #373475 Thu Feb 14 2013 12:14pm
FBH
All totally normal. RRS gone
Post #373476 Thu Feb 14 2013 12:15pm
whiskey mac
thanks for info only had since oct still learning whats norma land wots not with rrs Exclamation
cheers paul paul
Post #373479 Thu Feb 14 2013 12:55pm
We usually see an influx of smoke out of bonnet/smoke from fron wing threads around Nov time Thumbs Up
It's got a temp trigger of 4 or 5 degrees, so once the temps dip below that figure the Fuel burner is activated to aid heat the engine.
Thumbs Up RRS gone
Post #373485 Thu Feb 14 2013 1:45pm
Welderman
2009 Range Rover Sport TDV8 HSE Java Black
I did a search after mine did it last week lol, this sites great for looking up stuff for the RRS Very Happy Newbie near Chorley.
TDV8
Post #373487 Thu Feb 14 2013 1:53pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
FBH comes on automaticaly at temperatures below 5 degrees when the engine is cold to assist warming up. If you have the remote control / timer the FBH can be activated manually (park heat) MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #373525 Thu Feb 14 2013 7:38pm
