Home > General > My wondows always get fog on them after I drive t he RRS...
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
When I turn the car off all the wondows get foggy.
Does any one have this problem?
What could be the reason? 91 BMW 850CSI
Post #372020 Sat Feb 02 2013 11:49pm
Renaco
I dont have that Problem in my rrs.
Had it in my Saab and it was coming from the air condition.
It was an open flap on the inner way to the window, this floatend after stopping
the Engine the dust from the condensator into the inner car.
Maybe thats a similar Problem?
Best,
René
Post #372021 Sun Feb 03 2013 12:11am
dryden1407
Scotland 2013 Range Rover Sport SDV6 HSE Luxury Fuji White
depends if you are alone or with company Thumbs Up
if you are alone you have a problem 2013.5 rrs black edition in white here now
Post #372022 Sun Feb 03 2013 12:12am
panda
Rolling with laughter
Post #372023 Sun Feb 03 2013 12:15am
Fatandre
I see where this is heading, but this happens when no body is in the car.
Will take some photos tomorrow. 91 BMW 850CSI
Post #372025 Sun Feb 03 2013 2:07am
oldcro
Scotland
Do you switch your Air Conditioning off or leave it on all year?
Switching it off can cause fogging.
Post #372027 Sun Feb 03 2013 2:19am
Fatandre
Well.
It is on, but I was wondering that it could be missing some fluid.
I bought the car recently and it has no maintenance history and I doubt there has anything been done except the nessisery. 91 BMW 850CSI
Post #372028 Sun Feb 03 2013 2:30am
There could be water sitting in the system. There is a drain somewhere under the vehicle that allows water to escape when the air con is running on damp days. If this is blocked then the water can't get out and you get fogging. 2012 SDV6 - it's missing a couple of cylinders
Post #372030 Sun Feb 03 2013 8:15am
Check for wet carpets
I only get misted windows when I have been out in the rain and brought a wet coat in
Post #372031 Sun Feb 03 2013 8:40am
JC1
As NIck says check for damp/wet carpets.
Do you have a sunroof because these are also prone to leaking if the drain pipes are blocked water can run down the inside if the windscreen pillars.
You can normally smell if its damp inside MY10 3.0 HSE Santorini Black, Ivory Premium & extended leather, privacy, paddles, diamond turned alloys, Ipod lead that charges, tasmods, rrsport.co.uk stickers
Jeep 4.0 High Output XJ 94 6" teraflex lift, c/w rear coils, 9500lb winch, 35" TSL super swamper boggers, safari snorkel, custom made bumpers, tom woods custom double cardon driveshaft, twin electric fans. Don't follow it..............you wont make it. The first 4 x 4 by far.
Post #372032 Sun Feb 03 2013 9:07am
Fatandre
I will check the carpets and how can I check the drains?
If the drains are clogged, where does the water go? Wet carpets? 91 BMW 850CSI
Post #372044 Sun Feb 03 2013 11:39am
mlines
What year model is it?
My 2007 I could leave the Aircon on "AUTO" 100% of the time and it would deal with anything.
My 2012 mists up in cold damp weather and I have to manually turn the fans up to clear it. Although on AUTO it does play with the fan speed and heat on its own I feel it has a different programme to to 2007
Martin 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #372050 Sun Feb 03 2013 12:45pm
Fatandre
Its a 2006 91 BMW 850CSI
Post #372051 Sun Feb 03 2013 12:53pm
Fatandre
If my drains are clogged and I have been having this for some time. Could I be looking at some rust damage? 91 BMW 850CSI
Post #372053 Sun Feb 03 2013 1:58pm
Fatandre
I have found out that on my LHD RRS the footwell is wet.
Would that be from the sunroof or the a/c drain? 91 BMW 850CSI
Post #372200 Mon Feb 04 2013 5:16pm
