![]() | Home > General > My wondows always get fog on them after I drive t he RRS... |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 ![]() ![]() |
I dont have that Problem in my rrs.
dryden1407 Member Since: 22 Jan 2013 Location: montrose Posts: 65 ![]() ![]() ![]() |
depends if you are alone or with company |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
I see where this is heading, but this happens when no body is in the car.
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
Do you switch your Air Conditioning off or leave it on all year?
Well.
There could be water sitting in the system. There is a drain somewhere under the vehicle that allows water to escape when the air con is running on damp days. If this is blocked then the water can't get out and you get fogging. 2012 SDV6 - it's missing a couple of cylinders
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Check for wet carpets
JC1 Member Since: 24 Oct 2009 Location: Berkshire Posts: 939 ![]() ![]() ![]() |
As NIck says check for damp/wet carpets.
I will check the carpets and how can I check the drains?
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
What year model is it?
Its a 2006 91 BMW 850CSI |
If my drains are clogged and I have been having this for some time. Could I be looking at some rust damage? 91 BMW 850CSI |
I have found out that on my LHD RRS the footwell is wet.
