![]() | Home > Faults & Fixes > HELP: Transmission fault messages? |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
BTW at first HIGH and LOW ranges was inactive and after absolute possision sensor reset program ranges starter to work but not special programs which were still off
SportsTDV8 Member Since: 20 Jul 2012 Location: Berkshire Posts: 8 ![]() ![]() ![]() |
Hi All,
Brake switch has two position switches. Upper switch is activated when the pedal is touched very soft just to release cruise control but not to light the brake bulbs in back and the lower switch position is for brake lights to turn on.
Thanks - I'll order the switch and give it a try |
Switch delivered today (£12 + £2.50 postage)
Good to hear it from you ![]() |
SportsTDV8 disassemble your old switch and take a close picture to see how it looked like from the inside.
Picture of dismantled switch with signs of shorting/burnt switch
siim Member Since: 25 Aug 2014 Location: Tallinn Posts: 1 ![]() ![]() |
Hello,
