Home > Faults & Fixes > HELP: Transmission fault messages?
gruodiz
Lithuania
BTW at first HIGH and LOW ranges was inactive and after absolute possision sensor reset program ranges starter to work but not special programs which were still off
Post #370888 Thu Jan 24 2013 10:34pm
gruodiz
Lithuania
Some pics in my gallery
Post #370889 Thu Jan 24 2013 10:34pm
SportsTDV8
Hi All,
I've had this same fault on an off for the past week. I noticed that the last 3 times it came on I was braking lightly so I got my daughter to sit in the car and push the brake peddle down so that i could check the bulbs were all working. Here's what I found....
When the brake was pushed down normally all bulbs came on and know errors given BUT if you pushed it down slowly you could get all the way down as far as it can travel without any bulbs coming on and all the errors coming up on the dash.
I guess this means its my break peddle switch that need sorting.
Does anyone know if it's a simple DIY job to replace or does it have to go in to a dealer because something need to be calibrated?
By the way, this forum is great, I've been lurking for months and found some great help and advice on here. Bow down
Well done all.
Thanks
Post #371108 Sun Jan 27 2013 6:42pm
gruodiz
Lithuania
Brake switch has two position switches. Upper switch is activated when the pedal is touched very soft just to release cruise control but not to light the brake bulbs in back and the lower switch position is for brake lights to turn on.
Check pics in my gallery I have one there disassembled.
Part code is XKB500110
Pretty easy to change, first disconnect your battery, then you need + screwdriver to open foot panel then find pedal switch there, remove it by twisting hard, don't remember which side, you'll see. Connect the new one and I would recommend you to do hard reset before connecting battery. It's done by connecting battery cables which goes from the car together (not battery terminals, you'll see short circuit). You will need some metal extension or wrench to connect them.
This should help before going to dealer.
Post #371123 Sun Jan 27 2013 7:49pm
SportsTDV8
Thanks - I'll order the switch and give it a try Very Happy
Post #371231 Mon Jan 28 2013 6:55pm
SportsTDV8
Switch delivered today (£12 + £2.50 postage)
Fitting took 20 mins
Problem fixed, no warning lights Very Happy
Thanks for your help Thumbs Up
Post #371582 Wed Jan 30 2013 5:49pm
gruodiz
Lithuania
Good to hear it from you Wink
Post #371593 Wed Jan 30 2013 6:27pm
gruodiz
Lithuania
SportsTDV8 disassemble your old switch and take a close picture to see how it looked like from the inside.
Post #371619 Wed Jan 30 2013 9:35pm
SportsTDV8
Picture of dismantled switch with signs of shorting/burnt switch
Looks like the culprit Wink
Post #371639 Wed Jan 30 2013 10:29pm
siim
Estonia
Hello,
I have same problem. I changed brake switch, but shows again TRANSMISSION FAULT TRACTION REDUCED...
Maybe I must change another parts...
Thanks for any help.
Post #434167 Mon Aug 25 2014 6:51pm
