Home > Faults & Fixes > My rear license plate not working. Fuse 4 and 10 are ok. |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 |
anyone? 91 BMW 850CSI |
Mon Jan 28 2013 2:28pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Have you tried changing the bulbs? 2014 L405 SDV8 RR Autobiography
Mon Jan 28 2013 8:51pm |
Yes, I did. 91 BMW 850CSI |
Mon Jan 28 2013 10:52pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
Hi Fatandre.
Tue Jan 29 2013 9:44pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
The rear latch switch gets corroded, it is a alloy hinge when the rubber in between the numberplate lights is pressed it pushes onto a micro switch. when the hinge part corrodes it does not move so does not press micro switch. You need to take the unit out from beneath the number plate panel and clean it up or replace it to get the top tailgate to open. Then you can access the eight screws to take the outer cover off to check connections. New switches on ebay about £25 itisme |
Wed Jan 30 2013 9:37am |
I have ordered the switch.
Wed Jan 30 2013 4:47pm |
