Home > Faults & Fixes > My rear license plate not working. Fuse 4 and 10 are ok.
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
My rear latch swith is not working. Could that be connected? 91 BMW 850CSI
Post #371048 Sat Jan 26 2013 5:05pm
Fatandre
anyone? 91 BMW 850CSI
Post #371212 Mon Jan 28 2013 2:28pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Have you tried changing the bulbs? 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #371270 Mon Jan 28 2013 8:51pm
Fatandre
Yes, I did. 91 BMW 850CSI
Post #371294 Mon Jan 28 2013 10:52pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hi Fatandre.
My guess would be the cables giong to the rear hatch..
Check so that connectors and cables are in good order.
Could be a broken ground..
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #371482 Tue Jan 29 2013 9:44pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: My rear license plate not working. Fuse 4 and 10 are ok.
The rear latch switch gets corroded, it is a alloy hinge when the rubber in between the numberplate lights is pressed it pushes onto a micro switch. when the hinge part corrodes it does not move so does not press micro switch. You need to take the unit out from beneath the number plate panel and clean it up or replace it to get the top tailgate to open. Then you can access the eight screws to take the outer cover off to check connections. New switches on ebay about £25 itisme
Post #371524 Wed Jan 30 2013 9:37am
Fatandre
I have ordered the switch.
Sadly it is 50 pounds in Iceland, but those are the prices here and buying off ebay might even be more expensive when the customs get a hold of it.
I will get the switch and then take a look at the light 91 BMW 850CSI
Post #371581 Wed Jan 30 2013 4:47pm
