Home > General > RRS chooses wrong gear on slow corners |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
can you not teach it using command shift, the gear box is supposed to learn your driving style, or so i though |
Fri Jan 25 2013 3:30pm |
Morpheus-RRS Member Since: 29 Oct 2012 Location: Lanarkshire Posts: 83 |
Have had the same problem on mine, went back into the dealer on Wednesday for a few warranty items one of which was the problem you described, they done a software update to the gearbox and adjusted the brake light switch which has bettered the situation but not cured it completely. I'm going to try it over the weekend and see how i feel and if still not happy then it will be back to the dealer again. Dave.
Fri Jan 25 2013 3:31pm |
Fri Jan 25 2013 3:32pm |
The trouble with the learning dynamic gearbox.
Fri Jan 25 2013 4:51pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
I find that switching to sports briefly before a roundabout makes the gearbox more "intelligent", but I only do it on occasion, can't be bothered most of the time.
Fri Jan 25 2013 5:36pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
Is a design issue in the programming of the gearbox - not acceptable but little that can be done. 07MY RRS TDV6
Sat Jan 26 2013 12:59am |
kryten22uk Member Since: 01 Dec 2012 Location: Croydon Posts: 36 |
How did you find it? I've just had that gearbox software update done, and hopefully it might sort the car out. |
Thu Jan 31 2013 2:13pm |
Shiny Silver Member Since: 16 Feb 2012 Location: Cambs Posts: 70 |
Beta testing again are we?...
Thu Jan 31 2013 8:28pm |
