![]() | Home > General > OEM v's spurious side steps. |
Big ken Member Since: 14 Nov 2011 Location: Airdrie Posts: 282 ![]() ![]() ![]() |
Ebay |
Peanut Member Since: 31 Jul 2012 Location: Leicestershire Posts: 110 ![]() ![]() |
Got mine from -
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
I was in the same situation - opted for the cheaper lookalikes - never had a problem - fitted within a couple of hours .If you can afford a little extra I would opt for the versions that come with the PRE CUT sill replacements a little less hassle than cutting your own. |
When you have fitted them make sure you give the aluminium trim a few coats of a good wax, this will stop them from tarnishing. |
That's strong money ![]() ![]() £149 delivered......but you can make an offer too ![]() Edit: I have no link to this advert ![]() MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it ![]() GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 ![]() ![]() |
looking to get the ebay ones aswell, heards lots of good feedback |
cmcb Member Since: 16 Jan 2013 Location: Edinburgh Posts: 33 ![]() ![]() ![]() |
I got mine from eBay and try are spot on. If you can get a set with pre cut sills as it will save a bit of faffing and effort. They are pretty straight forward to fit too RRS TDV8 HST
grass cutter Member Since: 13 Jan 2013 Location: manchester Posts: 4 ![]() ![]() |
Well thanks for making my mind up for me everyone, gonna get the cheapies and wax the ally trim.
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
When I purchased my sport it came with OEM steps and they were a bit scruffy so I ordered the eBay replicas to replace them, the eBay ones were exactly the same and I didn't even have to change the brackets as they were identical to the OEM ones so the new steps just slid on, took about half an hour and you would never tell they weren't the original ones |
+1 for going to apply wax to them, thanks for the tip Ady |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
I know that money is always a sensitive subject (so is everything on here it seems) but am I alone in seeing something strange in being able to afford to buy a RANGE ROVER, then spoiling the originality by buying cheap (many Chinese made) side steps? If the car itself represents so much disposable income that to buy some side steps means cheap facsimile parts, isn't it better to get a cheaper car? To me, a Range Rover would always be worth OEM parts. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
A similar thought went through my mind BKHK. These things aren't cheap to run at the best of times so trying to do it "on the cheap" seems a little silly. But some people manage it and good luck to them.
The wax isn't to keep them shiney, infact the aluminium trim isn't shiney at all ![]() ![]() |
Ady, just pulling your leg |
